A4 Sunroof (has mind of its own)
Old Oct 24, 2004 | 09:04 PM
Beerzo's Avatar
Default A4 Sunroof (has mind of its own)
'97 1.8 T sport
The sunroof when driving seems to change it's position randomly. It may open to the tilt position or it may slide open. But seems to adjust itself every now and again.
It tilts up even when the switch is in the closed position.
Anyone know if this is a common problem or know a fix for it.
Cheers
Old Oct 24, 2004 | 09:31 PM
Jestnomen's Avatar
6th Gear
Default RE: A4 Sunroof (has mind of its own)
That is a very common problem, in fact mine does it. I've never gotten around to fixing mine, but i've heard you can remove the switch and clean the contacts with some electrical cleaner. There is always the option to buy one from a junk yard if that doesn't fix it.
Old Oct 24, 2004 | 10:42 PM
CRAZYHAWK's Avatar
Radio Shack sell a tuner cleaner spray that works well.
Old Oct 25, 2004 | 12:01 AM
99a4audi's Avatar
clean it out with some tuner cleaner
Old Oct 26, 2004 | 03:18 AM
factorplayer's Avatar
Default this is what you need
check it out, this dude has a whole page on how to clean the switch.
http://www.kris-hansen.com/Audi/srswitch.htm
Old Oct 26, 2004 | 03:34 PM
brrman's Avatar
Default RE: this is what you need
yeah, Kris knows his stuff.
Old Oct 27, 2004 | 01:42 AM
AudiGirlie's Avatar
a similar thing happens to me, but i will close mine and then it will open up again. same solution will do?
Old Oct 27, 2004 | 05:00 PM
Probably. The same thing (closes then opens again) happens with my sunroof too. I'm going to use his article to clean the switch this weekend. I'll let you know how it works out.
Old Oct 28, 2004 | 04:57 PM
skippster86's Avatar
I tried it and it works wonders! the only hard part for me was taking the motor out of the white casing. i think i cracked it a little, but it still works okay. better than spending 70 dollars for a new one.
tariqahmad
Oct 16, 2009 11:49 AM
Capo Cam
Feb 18, 2009 09:01 AM
410ThirtyValve
Sep 19, 2008 04:17 PM
GETxSOME
May 11, 2008 08:25 PM
brightside06
Nov 12, 2007 02:59 AM
