A4 Timing Belt
Old Nov 7, 2006 | 01:26 PM
trollbooster's Avatar
Default A4 Timing Belt
Hi, I'm new here! I have an A4, 1,8litre 1995MY.
The cambelt has failed, and she won't start. What am I looking at to repair, please?
New valves, or
New Head, or
New Engine.
Any advice appreiciated
Cheers.
Old Nov 7, 2006 | 06:52 PM
CRAZYHAWK's Avatar
Default RE: A4 Timing Belt
Find an Independent Mechanic. You'll probably need another head.
Old Nov 7, 2006 | 07:00 PM
BadLuckAudi's Avatar
it all depends on what happened man, its possible that not too much damage occured but at the most your gunna need head work done and a new TB
Old Nov 7, 2006 | 07:01 PM
techbod's Avatar
depends on how mechanically minded you are ( some new valves/timing belt/tensioner ) to find a replacement cylinder head would be nice and simple but still you need a new belt and tensioner and the tensioner is probably the cause
Old Nov 7, 2006 | 07:13 PM
Thanks for the response guys. I was worried (as I had heard rumours) that the valves can punch their way through the piston crowns.
If it is just a matter of replacing the valves (and presumably guides if they have suffered) then I'll compare that with the cost of a new head. I'll pull the head off on Friday afternoon and check it out. I have been pricing up engines in case that was the answer.
My only other experience with Volkswagen-Audi was a week of pain while I changed an inlet manifold gasket on a friends Golf. (I didn't realise the head was supposed to come off to do it!) What are Audi like to work on?
TB
Old Nov 7, 2006 | 07:24 PM
techbod's Avatar
very rare for the valve to punch through the pistons or even damage the guides, many would say skim the head but I disagree as long as its removed right the first time ( same as putting it back on ) the torque sequence is important on the removal as much as on refitting, I have the specs if required
Old Sep 16, 2007 | 09:47 AM
Blimey - I've had this a year and no progress!
Well, I popped the head off (needed to buy an XZN tool to do it) Valves creamed, pistons look OK - couldn't even see a ding in them so I bought a second hand head.
Got all the bits but the headbolts are different !
Anyone know what the tool is, GSF are trying to sell me a 9mm RIBE but it rattles about in them like you wouldn't believe.
The 10mm is too big! Can you get 9,5mm RIBE? I am reluctant to us a tool that feels wrong.[/align]
Old Sep 16, 2007 | 09:58 AM
techbod's Avatar
its a female torx bit and you can buy a full kit for what you paid for that one
http://images.google.co.uk/images?gb...mp;q=torx+bits
Old Sep 16, 2007 | 01:15 PM
Thanks Dave, actually have found out it is a polydrive
Specialty Tool, Cylinder Head Socket, VW/AUDI # T10070 (Hazet: model 2579-9)
Specialty Tool, Cylinder Head Socket VW/AUDI # T10070
For the operation of the new Polydrive-cylinder head screws on VW-Audi engines 1/2" drive
Thanks again all.
Old Sep 16, 2007 | 01:24 PM
techbod's Avatar
ORIGINAL: trailbuster
Thanks again all.
that's the male type not like your other photo? no wonder it woudnt work
