A4 tweeters..
ha.. guess i took you a bit to literally.. maybe i will pull then apart and see what the deal is.. kinda sucks.. dam.. i bet the dealer charges out the assss for a new set
as for the head unit its a AVIC-D1 like stated above.. ooops just saw the edit.. didnt think the ohm would change becasue im using all the stock amps.
ya the door handle cover comess out but i dont think the tweeter covers do. Even if they did you wouldnt be able to get at them to disconnect or pop out. Do whatever you want but just be careful not to break anything i guess.
ill take the door apart.. its just so dam hard.. dont want to break anything, and I tend not to be patient when i take things apart.. same reason i dont want to do my headliner.. but im finally installing the amp this week so i might as well see whats up with the tweeters it bugs me, cant play anything loud. they just crack and pop and such
If I remember right its not going to be as simple as getting a new tweeter( if going to the dealer) I'm fairly sure that the tweeter is connected(wired) through the door speaker so your going to need a new set - now depending on if they sell them as a set or seperate I don't know - my rear deck woofers were sold seperate but they also listed for $210/each - OUCH -
well it would draw less current i would ausme.. might not work because the tweeter might not get enough power.. why would it be 1.5ohm for a tweeter.. that seems really really low..
Thats the independance that Bose uses for it speakers I think - it was somthing weird 1.5 or 2 ohm something like that. its a way for them to make sure that you have to come back to them. Got any good junk yards around your area?
