A4B5 rear diff; compatability? LSD?
Old Feb 22, 2007 | 04:29 AM
Al_'s Avatar
Al_
Default A4B5 rear diff; compatability? LSD?
First off, my 99.5 A4 wagon does not have an LSD rear differential. I'm a bit peeved by this because I had been told all along that the rear was limited slip.
Back on subject...
I was getting noise from in back and found one of the rearoutput shafts to be loose. The issue is a simple bearing, nothing special.
I got the thing taken compltely apart and discover that I have a simple differential back there! No limited slip. This explains why I couldn't get moving when I had two wheels on ice a few months ago.
So, here are my options:
1. Rebuild current diff and get an lsd to go in it. I don't know where to start for this and would rather do option 2.
2. Get a completerear diff, housing and all,from another A4/(S4?/A6?) which is compatible. Hopefully, one with LSD. I do not know whatcan be swapped in,so I started this thread.
Specifications:
1999.9 A4, 1.8t,quattro, 5spd, avant
Differential Code = DAJ
Differential ratio = 3.889
Old Feb 22, 2007 | 01:27 PM
JohnnyBravoA4's Avatar
Default RE: A4B5 rear diff; compatability? LSD?
I think the a8 rear diff is limited slip and there is a thread on audizine about it.. look it up over there.. or if i come across it ill post up a link
Old Feb 22, 2007 | 02:46 PM
Lazer Viking's Avatar
stasis rear diff
audib5a4
Feb 6, 2014 07:50 PM
moneyfresh
Sep 3, 2012 04:53 PM
deadeyeknight
Jan 24, 2010 07:34 PM
jj2345
Jul 10, 2008 10:07 PM
