About to buy an A4 Quattro - PLEASE HELP - SERIOUS ADVICE NEEDED
RE: About to buy an A4 Quattro - PLEASE HELP - SERIOUS ADVICE NEEDED
the fuse for the washer pump is probably blown. the wipers will still work but u cannot spray any fluid. I don't remember exactly what the fuse is labeled but i think it is something like "intelligent system" , i am not sure. i called the dealer to get the pump replaced because the "wiper system" fuse was still good and i didn't think that i saw any blown fuses when i was looking at the panel, so they said that it is prolly the fuse because from the factory the fuse is under rated and marked wrong. So if there is a blown 20 amp fuse you can replace it with a 25 or 30 amp fuse.
... what is that supposed to mean?
like seriously I come on the forum for help and legit advice and I get some good responses which I definitely are appreciative
and then i hit some of you ******. If you have nothing good to say then STFU
even BMW ppl on forums are nicer
#20
ORIGINAL: ejc317
You should know after posting about so many stupid problems about a car to not buy it. Its common sense, which is something the bimmer forums lack by the way... Maybe youll fit in better over there.
