ABS/Brake Light
Okay, I searched for a possible cause, I checked the fluids, all that is left is the sensors.. I have felt it stiff to push the brake when the light is on..
So would it be the sensors or something else. On hondas (yes I own a accord, as well), the abs is pretty much useless after 10 yrs.. Would it be the same on the A4?
Thanks
Thanks
i think tat the sensor is more likely do to low brake pads. Check them and then tell us what they were like. If not that u prolly need to take it in or connect to a vag-com and get the code.
ORIGINAL: apg96
Low Brake pads? Hmm, going to check that.. But the light is intermittent and usually comes on when you hit a bump.. Or when I say strange the light doesn't come on for me to my wife.. lol..
Thanks fellas, I guess it's time to start ordering a few new things..
Try to vag it, if you cant connect to the abs control module, then the module is shot. Thats a $2400 problem. If it does connect it will tell you which sensor it the problems
my abs/brake light is on as well, drive down a hill i had to pess the brakes lightly and the abs just went heywhire, the pedal was vibrating like mad and then it stopped, then the light went on, my abs doesnt work nemore
please dont tell me its a new module
Pbcrazy
Sep 7, 2012 04:25 PM
gertron30
Feb 1, 2010 06:34 PM
Splbasshead
Feb 2, 2009 08:17 PM
