adjusting E-Brake...
Old May 1, 2007 | 09:16 PM
Lopster99's Avatar
Default adjusting E-Brake...
Maybe im just dumb...
How the heck do i tighten my ebrake??
thanks..
Dennis
Old May 1, 2007 | 09:46 PM
auditech79's Avatar
Default RE: adjusting E-Brake...
Parking brake, adjusting
Note[/align]
t
The rear brakes are self-adjusting, so the parking brake does not require adjustment in normal operation. Adjustment is only necessary after replacing parking brake cables, brake calipers, brake pads or brake discs.
t
The parking brake system must be bled and must be functioning properly.
t
The parking brake lever, parking brake cables and brackets must be fully installed.
Adjust lever position at brake calipers using feeler gauges to ensure that A = 1.5 mm.
Depress brake pedal firmly at least three times.
For ease of illustration the diagram shows parking brake lever removed from vehicle.
Press release button -2-. (Both spring-loaded hooks must catch eyelets on parking brake cable).
Let go of release button.
Firmly apply parking brake lever at least 3 times.
Place parking brake lever in rest position.
Press release button. (Both spring-loaded hooks must catch eyelets on parking brake cable).
Remove feeler gauge from brake calipers.
Check lever position at brake calipers.
Distance A between lever and stop must be between 0 and 1.5 mm.
Old May 1, 2007 | 09:49 PM
auditech79's Avatar
Old May 1, 2007 | 10:00 PM
Lopster99's Avatar
Thanks alot, very helpfull thread!
nrowensby
Jun 4, 2008 08:57 PM
Skipponator
Dec 17, 2007 01:36 PM
02A418T
Jul 17, 2007 09:01 PM
Authin
Aug 27, 2006 05:11 AM
PES_supercharged
Aug 30, 2004 03:35 PM
