adjustment for windscreen washer
The windscreen washers are fitted to the underside of the engine hood (or as Aussies would say: bonnet). The water stream from the passenger side washer hits the glass low down; so I need to adjust it upwards so it does a better job of wetting the glass. How do I adjust the angle of spray please? Do I attempt to bend the mount or is there a more civilised form of adjustment. TIA .... Greg
the nozzle might be dirty, i had the same problem with mine, i took an old toothbrush and scrubbed the sprayer and it seemed to work for mine, i wouldn't try to bend it, you don't want to break it.
