AEB-ANB-ATW-AWM-APU-AJL
Old Nov 4, 2006 | 03:30 AM
omastouris's Avatar
Default AEB-ANB-ATW-AWM-APU-AJL
even though the engine is the same, meaning 1.8t , there seems to be more than one engine type from 96-01 for the legendary A4. i'm in the market for an A4 and i have spent ENDLESS HOURS of searching millions and millions of websites but i can't seem to find one that has every engine by code (ex. the AEB engine or the AWT engine or the APU engine) Basically i want to find a comparisan for all the engines so that way i will know which one is the right one to buy?something with compression ratio's-what kind of turbo's-which intake manifold was bigger- that kinda stuff. I havent found it on ANYBODY'S forum's .Any help will be greatly appreciated. thanx[sm=dontgetit.gif]
[IMG]local://upfiles/25998/962B391961AE43ADA097DA0080C61C68.jpg[/IMG]
[IMG]local://upfiles/25998/36BFC2669F07484F8DCC51C9902359C9.jpg[/IMG]
Old Nov 4, 2006 | 03:39 AM
onepoint8tee's Avatar
Default RE: AEB-ANB-ATW-AWM-APU-AJL
Look here:
Dont pay attention to the 2.7-thats just for S4's
[IMG]local://upfiles/10408/1AC13438ADA749F2A5F76584F66B6187.jpg[/IMG]
97-99.5 years are NDBW and best for tuning for the 1.8t. Face lift in 99.5 and ndbw is most desireable if you are moding.(AEB engine code)
00+ are DBW
Old Nov 4, 2006 | 04:17 AM
omastouris's Avatar
thanx.....i saved that for future viewing. what about the 2000-2001 model? arent those even BETTER to mod ? you would think since there newer...but what do i know.
Old Nov 4, 2006 | 04:39 AM
18T's Avatar
18T
well it really depends on what you want to do.
Old Nov 4, 2006 | 05:03 AM
omastouris's Avatar
Depends on what i want to do.....................?
i wanna know excactly what the compression ratio is. i wanna know which engine had bigger intake ports.i wanna know which turbo the engine came with.
i need a comparison chart for all the engines -by-code- listing all these things.it has to be somewhere. i have looked forever and it doesnt seem to be posted on any sites. not under any 1.8t forums or sticky's.i think that if modders knew this information then they would know excactly which engine suits them. what do u think?
Old Nov 4, 2006 | 07:43 AM
techbod's Avatar
AJL 1.8T has the most power introduced in the UK from 1997 - 2001.
132kW (180hp) at 5700rpm
Old Nov 4, 2006 | 11:00 AM
JettaRedII's Avatar
This will help a little: http://forums.vwvortex.com/zerothrea...35912#29935912
When someone asks what you want to do with it, it's not a stupid question. The nDBW cars are less tempermental than the DBW cars. Mainly because there's less controls. If the ECU doesn't like what it's seeing in a DBW car, it can (1) close the throttle body, (2) open the diverter valve, or (3) open the wastegate, to name a few. The nDBW cars don't have a MAP (manifold air pressure) sensor, so boosting high isn't going to send you into limp. (However, lots of misfires may.) If you are going to use a stand-alone ignition system, then nDBW cars may be easier. Plus, GIAC has an excellent and matured program for the AEB, but only "recently" for the AWM engine.
Newer isn't always better!
Old Nov 4, 2006 | 12:41 PM
acetrebo's Avatar
AEB has the most modding potential, for many searchable reasons.
justr trust us, you want the AEB.
Old Nov 4, 2006 | 02:55 PM
omastouris's Avatar
THANX alot for all the help. just one more dilemma ----------------in '99 it sez it the A4 uses the AEB engine and in 2000 it uses the ATW. does anybody know for a fact if the 1999 and the 1999.5 have this AEB engine or did it turn into a ATW for 1999.5 ??????????????????[sm=groupwave.gif][sm=massbounce.gif]
[IMG]local://upfiles/25998/E225B543EF5840BAB9B16E074473801F.jpg[/IMG]
[IMG]local://upfiles/25998/BC95A56C54FA4957B07813BB3510EA73.jpg[/IMG]
Old Nov 4, 2006 | 09:51 PM
acetrebo's Avatar
I believe it is aeb until 1999.5.
That white audi is hot.
