Airbag help !
Old Feb 12, 2005 | 06:41 PM
Ricoh's Avatar
Default Airbag help !
Hi gentlement.
Audi A4 1.8T 2000.
Recently, when I turned on my Audi, the airbag light was appearing. I've spoken with someone here, and he told me I need to
change airbag control.
It's true or I can do something?
This is the code:
VAG-COM Version: Release 311.2-N
Control Module Part Number: 8D0 959 655 K
Component and/or Version: Airbag Front+Seite 1002
Software Coding: 00104
Work Shop Code: WSC 06335
1 Fault Found:
65535 - Internal Control Module Memory Error
00-10 - - - Intermittent
Thanks for your support .
Old Feb 12, 2005 | 09:22 PM
mecknic's Avatar
Default RE: Airbag help !
that code usally means the control unit needs replacement. airbag control unit check themselves and if they find internal faults they will stop operating, it's a liability issue. don't forget your coding, a new control unit will need that coding to tell it what the car has for bags etc.
Old Feb 13, 2005 | 02:42 AM
Ricoh's Avatar
Thanks !
Old Mar 2, 2005 | 06:56 PM
Ricoh's Avatar
The control module cost 600$ can + 160$ for installation in dealer. If I change myself, There is a procédure to change it ? Can I need unplug the battery , Can I run without this module. after can I reinstall the new one and work with my Vag Com for reprogram the code,
Thanks
Old Mar 2, 2005 | 07:04 PM
CheckMyVitals's Avatar
airbags are going to be a ton of money... s'why i had mine stolen. but for good reason, airbags are one of the only things i won't do myself. when i had to have mine replaced i had it all done at the dealer, i woudn't touch em. after all, the only time you're gonna find out if they work or not is when u get smoked...
Old Mar 2, 2005 | 07:14 PM
Ricoh's Avatar
Ok probably you have the best solution, I'm not realy intereted in having more problem with airbag .
Good way
Old Mar 2, 2005 | 07:22 PM
yeah man. any other repair or mod i highly encourage you go out, get the tools and learn something new about the car, and save some money. but airbags.... nah, i'll spend what it takes to do it right.
Edit: btw, the price you have there $700 inc. installation seems pretty reasonable.
Old Mar 2, 2005 | 07:32 PM
Ricoh's Avatar
Where do you from?
pologoped2
Jul 28, 2013 05:47 PM
Niclipse
Apr 11, 2011 05:29 AM
a4owner
Mar 13, 2008 03:31 PM
TheBat
Feb 6, 2008 02:29 PM
Avant1.8t
Aug 22, 2007 12:14 AM
