Airconditioning
Old Jun 27, 2007 | 01:53 PM
882DC's Avatar
Default Airconditioning
Hi there, im trying to recharge my AC on my 96 A4 2.8 Quattro, however i cant find the port were you recharge it at. I found the larger cold tube in the upper left corner where it should be, however no place to 'plug in' There is a sensor there where the port should be, is the port behind that sensor? Or is it somewhere else on the car?
Old Jun 27, 2007 | 01:58 PM
onepoint8tee's Avatar
Default RE: Airconditioning
You have to take the weather stripping/seal off the firewall between the battery and engine and slide the cover out to expose the charge lines/battery box/ ecu box/brake master cylinder.
Ari Conditioning = 2 words [8D]
Old Jun 27, 2007 | 02:24 PM
882DC's Avatar
well i took that sensor off, and there was a line there, however i couldnt get the recharge thing to stick on there. LoL lost more ac gas.
Old Jun 27, 2007 | 02:26 PM
What sensor?
Old Jun 27, 2007 | 02:29 PM
882DC's Avatar
are there different type of AC gases, one with a screw on type end?
Old Jun 27, 2007 | 02:30 PM
882DC's Avatar
im not sure what sensor. its connected to the low pressure line of the AC. I thought the port was behind it. Also i checked behind that weather strip, nothing behind that except the cabin filter
Old Jun 27, 2007 | 02:53 PM
This is where Im talking about, are you saying yours does not look like this?
[IMG]local://upfiles/10408/610C41F3CDA44E449F67152F0E1821A3.jpg[/IMG]
Passenger side corner by firewall.
I think the wrong one is circled in the pic, but thats where it should be located.
Old Jun 27, 2007 | 04:28 PM
882DC's Avatar
no your right, thats what it looks like. The sensor that im talking about goes out from the spot. The 2 lines, high pressruse and low pressure lines for the AC correct? Ill have to look again, but that rubber gasket there, i think its right agains my firewall. Ill post new when i look again.
Old Jun 27, 2007 | 04:35 PM
techbod's Avatar
[IMG]local://upfiles/12092/1C84F4A6E732412294D197C9888CAB82.jpg[/IMG]
Old Jun 27, 2007 | 08:15 PM
jkucz28's Avatar
thats weird because on mine the high pressure service port is right on the condensor when you open the hood... 96 2.8 as well.... and i was told by a tech friend at audi that you can only charge the high side with a 134 machine
btw mine does not look like that at all when you take the molding off
