alignment?
Old Mar 31, 2005 | 09:57 PM
turbo's Avatar
Default alignment?
Today I took my car for an alignment and had a question on TOE numbers, they were
LF .17deg
RF .13deg
LR .46deg
RR .18deg
Is that ok that LR was off so much?
Will that give me bad tire where? they said that was the best they could do, and said it will be fine.
Old Apr 1, 2005 | 02:22 PM
turbo's Avatar
Default RE: alignment?
Jestnomen I see you on, can you help me
Old Apr 1, 2005 | 02:35 PM
CRAZYHAWK's Avatar
Did they give you before and after toe in data?
Old Apr 1, 2005 | 02:39 PM
turbo's Avatar
No but they were real bad because in 3 months I killed my stock tires.
You were able to look down the side of the car and see that they were way off.
It is droped like 2" and that was what caused this I think.
Old Apr 1, 2005 | 02:52 PM
CRAZYHAWK's Avatar
Neuspeed give toe spec from +1/16 to -1/16
Old Apr 3, 2005 | 04:47 AM
turbo's Avatar
So do you think that the LR deg of .30 off will cause bad tire where?
Old Apr 3, 2005 | 11:48 AM
CRAZYHAWK's Avatar
I thought the LR was .46
Old Apr 3, 2005 | 02:52 PM
turbo's Avatar
It is .46deg but you post that neuspeed states it to be .16deg so I figured that would be, .46-.16=.30 am I wrong
Old Apr 3, 2005 | 05:27 PM
ImolaS4's Avatar
Bottom line: It ain't good.
I'd look into resetting your springs and having the car corner balanced, too.
kevintt
Jun 21, 2008 05:25 PM
kwaskow
May 23, 2008 06:08 PM
grrrrrrr
May 9, 2008 07:41 PM
wings7351
May 24, 2007 01:42 PM
ouTTie914
Aug 17, 2006 10:48 PM
