amp install for 96 A4
Old Apr 4, 2005 | 03:05 AM
1996a4's Avatar
Default amp install for 96 A4
Anyone have a diagram for a 96 A4? I am looking to install an amp but need to know
if factory radio has rca plugs or not. I have the factory changer but do not see any wiring for
an amp. thanks
Old Apr 4, 2005 | 04:38 AM
BFlan2001's Avatar
Default RE: amp install for 96 A4
if you have bose there is an amp back near the cd changer...if it's non bose i believe the amp is built into the stock speakers...but there should be rca cables either way...i would think..
Old Apr 4, 2005 | 05:29 AM
Karl's Avatar
I dont have the BOSE speakers in the back of my 96 A4.... So I looked and the rear speakers said "NOKIA" anybody heard of this?
Old Apr 4, 2005 | 05:32 AM
headshok2002's Avatar
well, check your head unit... if it says bose, its bose, if it doesnt, then your care is non-bose.
I have a 2000 a4, non-bose... and the amp was attached to the .... rear (i want to say drivers side) speaker. there are ways to bypass the amp, though I'm not entirely sure of how it's done. As for your RCA's... no clue dude. Upgrade your HU though, if it does have pre-outs, they are probably like 1 volt...haha, they will be weaaaaaaak.
Your amplifying stock speakers right, not adding a sub?
BFlan2001's Avatar
yea, those are just the stock speakers
Old Apr 4, 2005 | 05:35 AM
BFlan2001's Avatar
my car has the bose system and there are no Bose insignias visible anywhere...on the speakers themselves, the amp, and the HU display says "BOSE" for about 3 seconds when i start my car, that's it
Old Apr 4, 2005 | 05:38 AM
haha, yeah i forgot about that -- that it only shows up when you first turn the stereo on, it lights up BOSE for a few seconds. My bad.
Old Apr 4, 2005 | 06:17 AM
Karl's Avatar
Would check to see if mine is BOSE, but my HU has been upgraded allwell
Old Apr 4, 2005 | 11:52 AM
Jestnomen's Avatar
6th Gear
ORIGINAL: 1996a4
an amp. thanks
If you have the BOSE amp on a rack in the back then yeah there are "RCA" like cables in the back. Not tradional ones though, you have to splice into the factory wiring harness.
this is the plug on the back of the bose amp. Audi uses a common ground system. That means you'll have to take an RCA cable and crimp the two rca grounds to the line level common ground.
Old Apr 4, 2005 | 03:56 PM
1996a4's Avatar
wanting to install amp to subs with minimal modification to factory. So it is not a bose. says nokia on rear speakers. any ideas
