another bov tread
Old Dec 6, 2007 | 02:41 AM
cincyTT's Avatar
I'm make believe
Default RE: another bov tread
ORIGINAL: littleflavio
im confused i want a bov that is loud and is also safe
as im sure i have told you before, the forge004 is loud and works well when tuned correctly.
Old Dec 6, 2007 | 03:00 AM
littleflavio's Avatar
and im driving a b6 as i saw in some forums it will not fit any b6?
Old Dec 6, 2007 | 03:37 AM
wat do u mean by tuned correctly?
Old Dec 6, 2007 | 03:26 PM
cincyTT's Avatar
I'm make believe
all 1.8t cars use the same 710 stock dv. If a valve fits one, it fits them all. As for tuned correctly, i mean have the correct spring and shim if needed.
Old Dec 6, 2007 | 03:33 PM
A4Boy90's Avatar
Member
dude just get it its fine i have the forge 004 it works fine and its loud just make sure you plug up the other hose come to find out today my little getto plug crumbled into little parts so that's why i couldn't hear mine but its loud now....
Old Dec 6, 2007 | 07:48 PM
sean1.8t's Avatar
ORIGINAL: cincyTT
ORIGINAL: sean1.8t
with the B6, you won't have any problems running any BOV your heart desires. or any DV. it will run fine regardless..
the B6's are special
why are you going around spreading bad info? I thought you knew better [&o]
No you cant run ANY bov, just a certian style and even some of those work better than others. The key point is that its closed at idle andreleases a proper amount for the turbo used(tial 50mm on a ko3/4, thats a no go)
i was going to come back after a couple posts and explain that you need to remove your MAF also then you'll be alright. like me, single piston BOV and i run great. but no MAF also[8D].. but i got caught up in what, i can't remember, and spaced coming back[:@]
n e ways, the Forge 004, HKS ssqv, GFB steath, andForge Splitter will all work great.these dual pistonBPV'sremain closed at idle.
no one has ever been able to produce a log showing that a dual piston type BOVruns rich on the B6
also, modern BOVs are all dual piston or dual diaphram to avoid the leakage during vacuum
Old Dec 6, 2007 | 07:53 PM
chaos92287's Avatar
how did you remove the MAF? i thought you had to run standalone for that??
Old Dec 6, 2007 | 08:13 PM
  #18
cincyTT's Avatar
I'm make believe
map equipped cars can have the tunes made to run on the map alone. Having both (maf and map) is ideal.
Old Dec 6, 2007 | 08:31 PM
  #19
sean1.8t's Avatar
ORIGINAL: chaos92287
B6's are equipped with a Wideband o2, stock. the ECU is programmed from the factory with the target AFR, and it will adjust fuel trims accordingly to maintain that, tuned or untuned. a lot of B6 guys run no MAF and the car runs great..
but no, you can't run any MAP equipped car(like an ATW)without a MAF, some will run, but most will run like turd
Old Dec 6, 2007 | 08:53 PM
  #20
chaos92287's Avatar
oh, thats cool. can b7's do that as well?
