View Poll Results: A poll
Voters: 23. You may not vote on this poll
Another DV Poll... (no flames please)
So I've gone ahead and read through some of the previous posts about the different DV's and the pro's/con's and also read the posts at the top of the forums here. So I have looked.
Now for the question. I'm planning on going to at least a chip tune which will most likely be the GIAC since that seems to give better lowend power. Later on I may go to a K04 upgrade but it's not an immediate thing. So which DV is going to be the best deal for me do you all think?
I know that the 710N is the cheapest being about $50 shipped from ECS. Then there is the Forge 007 for $135 shipped from ECS. Then the Bailey is $165 shipped from AWE.
But what based on both price and actual quality should I go with. I mean if the Bailey is worth it because it does perform better then I'd pay the extra for it but if the 710 will work just as well then I'd go for it.
Thanks for any input...
Just get a 710N, it will be fine, I say there is no reason to spend 3x as much or more on a baileys. You wont feel a difference and the 710N will last a long time. Read this if you don't believe me.
http://dv.mistertam.com/8.htm
have you thought about the apr r1? Never needs cleaned, maintenced, adjusted/tuned. Plus it is a diaphram dv that will react much faster than the piston ones above and has a lifetime replacement warrenty on it. For $140, thats a good deal to me.
