Another problem
Old Aug 20, 2004 | 01:23 PM
Bashawin's Avatar
Member
Default Another problem
Now I am told that I need a electronic cooling fan. While driving with the air conditioner on the car started vibrating. Also while not running the air it did the same thing. But I was in bumper to bumper traffic on a very hot day. So I guess it was tring to help to cool the engine.
The other thing is I need to get a oil change. I want syn oil they say that it will add 42.00 more to the total. This would make the total 82.00 for an oil change.
Any comments?
Old Aug 20, 2004 | 03:28 PM
Jestnomen's Avatar
6th Gear
Default RE: Another problem
Is this the dealer who is telling you this? You may want to go to an independant euro mechanic for a second opinion.
Do the oil change yourself. With $40 dollars of equipment you can be changing your oil for ~$25 bucks a pop w/synthetic oil. It's cake.
Old Aug 20, 2004 | 05:39 PM
Bashawin's Avatar
Member
ORIGINAL: Jestnomen
[sm=dontgetit.gif]
No this is not the dealer.
I am mechanically callenged.
Old Aug 20, 2004 | 06:16 PM
Jestnomen's Avatar
6th Gear
haha, no really it is easy. Jack car up, remove oil fill cap, put pan under drain, remove drain, remove filter, screw on new filter, put drain plug back in, fill with new oil.
Old Aug 21, 2004 | 01:05 AM
Transverse's Avatar
Sounds fantastic!
Where/what is/are these wonderful $40 tools you speak of?
Mechanically...challenged...but getting there (a.k.a. I can follow directions)
Old Aug 21, 2004 | 02:58 AM
SlimChriz's Avatar
get a metric socket set up to 17mm should be aight then get a rachet thats enough to change the oil. the oil drain plug is 17mm I believe
Old Aug 21, 2004 | 03:35 PM
david9999's Avatar
My favorite mechanic (Walmart) will put in Mobil-1 5W-40 and change the filter (they supply Fram) or my own, for 32 dollars total.
Old Aug 21, 2004 | 03:43 PM
shon's Avatar
my mechanic (he works at goodyear) will change my oil w/ synthetic for $19.99 plus $8.60 for labor...
worth it to me...
Old Aug 21, 2004 | 03:59 PM
Bashawin's Avatar
Member
ORIGINAL: shon
worth it to me...
[sm=smiley32.gif] WOW Shon where do you live?
Old Aug 21, 2004 | 04:35 PM
David_K's Avatar
my mechanic (me) will do it for about $20 including labor!!!!!!!!
