Anyone have a problem with radio reception from HIDs
Old Dec 20, 2007 | 07:16 PM
AudiA4Driver98's Avatar
Default Anyone have a problem with radio reception from HIDs
I've had my HIDs for about a year now and have been meaning to post this... Has anyone else had there radio reception go to crap when they turn on thereheadlights? It's only when I have them on and it's not like it's a loose wire or anything it was a real nice job.
Also, my AM reception is really shacky ever since I got my tints done... I assume it's because the wire for the radio is in the back windshield. Is there anyway to fix that? Maybe an after market radio?
Thanks...................................
Old Dec 20, 2007 | 07:24 PM
hiwords's Avatar
Default RE: Anyone have a problem with radio reception from HIDs
the antenna can be extended. i believe there's a diy for that. the wire is in the back of the car somewhere. as for the bad reception when the headlights are turned on, it could be a bad ground somewhere. my radio works perfectly no matter what i have on or off
Old Dec 20, 2007 | 07:58 PM
Thanks a lot, first where would I be able to get extra antenna. Also, How would I go about fixing the ground affect if that's the problem?
Old Dec 20, 2007 | 08:07 PM
hiwords's Avatar
you can get wires from radio shack or circuit city. as for the grounding you would have to follow the wires from behind the headunit. it's gonna be a tedious job.
Old Dec 20, 2007 | 08:11 PM
Thanks, I'll see what I can do in the next few days.
Old Dec 20, 2007 | 08:14 PM
hiwords's Avatar
check behind your radio first, jsut found this https://www.audiforums.com/m_36860/tm.htm
toolagit2qwit
May 3, 2011 09:26 PM
bplac479
May 27, 2010 09:00 AM
5up3rman
May 6, 2010 12:35 PM
r1chp
Dec 12, 2007 07:41 PM
catser911
Feb 4, 2006 09:06 PM
