Anyone know how to fix...
Old Jan 25, 2008 | 11:10 AM
cer7ifiedhustle's Avatar
Default Anyone know how to fix...
Hey does anyone know how to fix power locks. Also the sunroof doesnt open and i searched and found how to clean the sensor. Is there anything else i should know? Thanks!
97 a4 quattro 2.8L 5 speed
Old Jan 25, 2008 | 11:23 AM
tdn's Avatar
tdn
Default RE: Anyone know how to fix...
It's probably your vacuum pump, do a search for it. Buy a used one and replace it yourself, otherwise getted bent over at the dealers. A used one at a junk yard should cost you around $150. Dealerships might cost you $500 or more for the same thing. Do a search, I only know this info because it's been discussed before.
You might also have to get your key reprogrammed.
Old Jan 25, 2008 | 12:28 PM
chaos92287's Avatar
sensor is usually for random opening sunroof, but still worth a try, if not it might be a relay (i have an extra one for less than you'll pay at the dealer) or a fuse.
