it apparently loves oil
Old Nov 29, 2005 | 09:04 PM
S4sweeteeteeRS's Avatar
Default it apparently loves oil
ok, theres no oil leak, at least nothing on gagage floor. had to add a quart at 5000 mi and another quart at 9100 mi. my car is the 4.2 engine S4. (no one would answer me on that forum). anything specific i can ask the dealer to look at? generally, i dont drive it hard (except for the 2 road trips i took) does this engine just drink the oil the same way it drinks the gas or do you think ther is a problem? any comments would be appreciated.
Old Nov 29, 2005 | 09:17 PM
Quartz05's Avatar
Default RE: it apparently loves oil
The rule with oil consumption is that it can only go two places - either onto the ground or out the tailpipe. If there's nothing on your garage floor check around the valve cover gaskets and all other places that you might find traces of oil leakage that wouldn't make it to the ground or that would only leak under pressure, i.e. with the engine running. If nothing, then you're burning it. Probable causes include rings and valve guide seals.
Old Nov 29, 2005 | 09:48 PM
AudiTech04's Avatar
Tell the dealer you had to add oil
Also there could be a minor leak that the belly pan is preventing from reaching the floor
audiboy1618's Avatar
How often do you change ur oil? I would try changing it way before 9100mi, may be why ur car is leaking somewhere.
Old Nov 29, 2005 | 10:01 PM
i changed it at 5100 miles and will have it changed again soon at 10,000.
thanks for responding.
Old Nov 29, 2005 | 11:03 PM
headshok2002's Avatar
A quart in 5000 miles is nothing to worry about... car companies allow for a certain amount of oil consumption... there is a point, where if you burn more than X amount, they consider it a problem. But ALL cars burn some oil, it's just a matter of how much.
tonyje
Aug 31, 2011 04:56 PM
02AvantImola
Mar 12, 2009 11:18 PM
theTTkid
Mar 17, 2008 11:58 PM
audi_pa
Aug 30, 2006 10:47 PM
bluovalguy
Jul 27, 2005 03:57 PM
