apr 1+ inconsistent boost problem
Old Apr 1, 2007 | 01:51 PM
crd945's Avatar
Default apr 1+ inconsistent boost problem
After I got APR 1+ installed I have been having a problem. For periods of about 10 minutes my car will randomely not boost past 8 or 9 psi. This has happened twice to me so far. My car will then suddenly begin boosting normally to a little under 20 psi. I have the n75j valve.... do you think that it might not agree with apr 1+ because it is already asking for such high boost?
Old Apr 1, 2007 | 01:53 PM
onepoint8tee's Avatar
Default RE: apr 1+ inconsistent boost problem
you just got the 1+ so id give it a couple weeks to adapt before you start getting worried.
It is possible the J valve is not a good match with the 1+ software.
Old Apr 1, 2007 | 07:42 PM
crd945's Avatar
ok now I switched the N75 back to the stock one(made sure I put it in the right way... long tube into the intake and the wire pointing up) and now my car is in limp mode boosting no more than 5psi. I restarted the car... made sure everything was still plugged in right and tried it again... and still in limp mode. What could cause this?
Old Apr 1, 2007 | 07:46 PM
Jeff's Avatar
Zombie Defense Force
you have to reset your ecu by unplugging your neg battery terminal for a few minutes before you get out of limp mode. sounds like you might need a mbc.
Old Apr 1, 2007 | 07:56 PM
crd945's Avatar
just unplugged it.. how long should I leave it for
Old Apr 1, 2007 | 08:33 PM
crd945's Avatar
full boost is nice... unplugging the battery worked. thanks onepoint8tee.... and jeff
DonBergen
Apr 2, 2012 10:42 PM
kwaskow
Oct 27, 2008 10:45 PM
warranty225cpe
Jul 19, 2008 01:24 PM
bluesnapper
Nov 16, 2006 09:11 PM
bluesnapper
Oct 20, 2006 01:05 PM
