ATW engine LWFW?
I just put a fidanza in my car which also has theATW engine. I used the Fidanza AEB flywheel, the only difference is in the flywheel mounting bolts. The ATW uses 22.5 mm while the AEB uses 43mm. The Fidanza works fine as long as you buy the longer bolts.
By the way, the Fidanza is awesome, a fair amount of gear chatter when idlingwith the lights and A/c on, but thats typical whenever you reduce the weight by more than 50%.
