Audi A4 brakes
Old Oct 12, 2007 | 08:01 AM
dpace32's Avatar
Default Audi A4 brakes
Hello- i recently purchased a 2003 Audi A4 w/72000 miles that has extremely squeaky brakes. the problem only seems to happen for a couple minues (ie until i back out of my driveway) does anyone know what this might be?
Thanks!
Old Oct 12, 2007 | 08:11 AM
hiwords's Avatar
Default RE: Audi A4 brakes
don't worry too much bout it. it's just he rust that builds up over night and then it goes away after ur brakes warm up.
Old Oct 12, 2007 | 08:12 AM
klum00's Avatar
if it becomes more persistant, it's probably time for new pads. easy DIY so just pop one of your wheels off sometime and look to see how much of hte pad is left.
Old Oct 12, 2007 | 10:16 AM
kriptonik's Avatar
Just to be save you should check if your pads are still good.
Incase you can still save the rotors and also save money.
Old Oct 12, 2007 | 06:16 PM
david9999's Avatar
The first answer is likely the correct one. If itis just first thing in the morning, and the first or second time you apply your brakes, it is likely rust forming on the rotors overnight. Common and normal. I'm assuming that you park outside and that you are in a damp climate.
Old Oct 12, 2007 | 07:52 PM
kolan67's Avatar
what if its squeeky after driving all day?
Old Oct 12, 2007 | 07:58 PM
hiwords's Avatar
then u either got bad pads or rotors. most of the time it's the rotors. chekc them both and get a can of brake cleaner and hsoe things down. don't use the brake cleaner when the brakes are hot though
Old Oct 12, 2007 | 08:22 PM
fcamargo6thave's Avatar
I have the same problem and took it to the dealer and they said that the brakes have to wear down alittle Dpace22 keep me posted my have been squeeking alot for months took it to the dealer 3 times and they never tell me to change my brakes instead they just say wait it out they will stop squeeking but u will get pissed once they sound like a bus trying to come to a stop.. it is true thought the rust does create a problem because i have the same problem but when i start driving there is not squeeking only when i have been driving for about ten minutes keep me posted if u get it fixed tell me hat u did
Old Oct 12, 2007 | 08:26 PM
hiwords's Avatar
if they squeakafter u've been driving then u definitely have a problem. i wonder y the dealer won't change ur brakes for u. i mean it's not under warranty. i'd thought they would have luv to have a chance to rape u like they always do.
Old Oct 12, 2007 | 11:16 PM
dpace32's Avatar
ORIGINAL: hiwords
That sounds like good news! Is there anyway to reduce the noise though? I live in the north east and it is starting to get cold / damp in the morning and I do notice a very small amount of rust building up on the breaks... does break cleaner actually work for this?
Thanks again!
