Audi A4 Heat Problem...NEED HELP ASAP!
Old Jan 16, 2008 | 09:09 AM
smoovmusicdj's Avatar
Default Audi A4 Heat Problem...NEED HELP ASAP!
Hello,
I need some help with my 99 A4 Quattro. Ok, I recently got my coolant flushed many times over again but I am still not getting HOT HOT heat....just warm at times. It seems that the Thermostat is working fine but fluctuates at times. Any idea what this could be? PLEASE HELP!
**The heat is set @ "HI" at all times but does not blow warm at all unless on the freeway....then a little warmer.
Old Jan 16, 2008 | 10:54 AM
rsrbljan's Avatar
Default RE: Audi A4 Heat Problem...NEED HELP ASAP!
Is the car getting up to temp? It can be only a few things. If the car is not getting to temp, then you have a stat stuck "open" which is better than closed. It will result in lower MPG, a cooler running temp, and longer warm up periods, little to no heat until fully to temp... which sounds like what you've got going on. If the stat truely is fine, then it has to be something in the heater core. I'd think it'd be a clogged core, and I've had them not be "flushable" before.
I'd start there, hope it helps.
-Ryan
Old Jan 16, 2008 | 11:02 AM
FASTER's Avatar
Tech Slut
could be a weak water pump
The TStat gets up to about 1/2 about 25% of the time and then other times it will stay a mark under the half point. But to get up to 1/2, it takes sometime....maybe 20-30 minutes of driving. Let me know.
Old Jan 16, 2008 | 11:03 AM
Old Jan 16, 2008 | 11:09 AM
hiwords's Avatar
this sounds silly but did you bleed the system right? and when was the last time you did the timing belt service?
Old Jan 16, 2008 | 11:14 AM
I had my coolant flushed and unsure what you mean about bleeding the system! And timing belt....NO! THANKS!
Old Jan 16, 2008 | 11:20 AM
hiwords's Avatar
there are 2 black hoses by the battery. they are like 1.5" big or so. one of them has a tiny hole on the side which is a bleeder hole. you need to bleed the system there or you won't get heat. there's been tons of posts like this too. do a bit of searching and you'll know exactly what i'm talking about. i jsut woke up so i may be a bit unclear on some things lol
iwonder
Dec 11, 2015 06:37 PM
smoovmusicdj
Jan 3, 2008 06:12 PM
smoovmusicdj
Aug 24, 2007 01:14 PM
smoovmusicdj
Aug 17, 2007 09:52 AM
K1196A
Dec 29, 2006 01:18 PM
