Audi A4 missfire
Old Jul 5, 2007 | 03:48 PM
mickyboy10001's Avatar
Default Audi A4 missfire
Hi everyone out there,
Ive got a problem with the car, cel came on, pulled the codes and none came up but when i pulled one of the ignition leads out from the spark plug [plug 2]the car was still ticking over the same as before but when i pulled plug 1 the engine sound changed as if running on three cylinders as it should but both plugs were giving out a spark when i placed them near metal,I found this very strange, however as i pulled on the throttle body to rev it up the spark didn't seem brighter or larger just faster, i wonder can one poor lead actually make the car hard to start, but still allow it to tick over rough 800-1000 but when you rev it up make it missfire, just to add I did spay some wd40 on the leads and it started better but still missfired 5 mins later any ideas please
Old Jul 5, 2007 | 05:44 PM
koenigar17's Avatar
Default RE: Audi A4 missfire
coil pack?
Old Jul 5, 2007 | 05:46 PM
Boostfed13's Avatar
What year what engine?
Old Jul 6, 2007 | 05:35 AM
have changed coil pack the engine is a 97 non turbo
Old Jul 6, 2007 | 10:19 AM
Rallyrcr1500's Avatar
Try the MAF Sensor on your intake. Mine got wet and corrosion set in. Just sane sand paper and a file fixed my problem. Then I had the code cleared.
Sleety
Feb 9, 2025 12:47 PM
Jonh F.
Sep 9, 2013 09:37 AM
kuron1990
Jan 13, 2013 12:37 PM
chris-a41.8t
Oct 20, 2009 09:03 PM
Ecureuil
Apr 25, 2007 11:46 PM
