AUDI ABS MODULE REBUILD * PLEASE READ
[color=#0033CC] If your vehicle is listed below and you are having ABS Failure , ABS & brake light on, We can rebuild your ABS control Module,Please look at the pinout image of the module we will need ohm readings from you this will help you in Verifying if you actually have a failed module, You will need to contact us @ Tech@autoecu.com for specific ohm ratings, Once you test/ohm , email your results back, We will inform you If the module has failed Inside.
We are offering a 15% discount on our rebuilds for all Audiforums.com Members, our regular price is $249.00 with a 5 year warranty. All you have to do is send your module in & include your Audiforums.com user ID. this will allow the 15% discount. we also have removal Instructions ,email us to request them tech@autoecu.com
Our Toll Free number is 1-800-257-3395 ext 30 Auto & Truck Electronics 6500 Georgia ave. West Palm Beach, FL. 33405 www.autoecu.com[IMG][/IMG]
8E0614111A, 8E0614111E
8E0614111B, 8E0614111F
8E0614111AH, 8E0614111AJ
8E0614111AA, 8E0614111T
8E0614111P, 8E0614111Q
8E0614111R, 8E0614111S
8E0614111M, 8E0614111N
AUDIA4 98 exc. Quattro; w/trac cntrl (ASR &
EDS)
AUDIA6 98 exc. Quattro; Trac Cont (ASR)
PASSAT 98 w/trac cntrl
PASSAT 99 exc. 4 Motion; w/o navigation
system; w/o elec stability control; w/trac
cntrl (ASR); ID 8E0
AUDIA4 98 exc. Quattro; w/o trac control; w/EDS
AUDIA6 98 exc. Quattro; Ele Diff Lck (EDL)
PASSAT 98 w/o trac cntrl
system; w/o elec stability control; w/o
trac control; ID 8E06141
AUDIA4 98 Quattro, frm VIN 007800
AUDIA6 98 Quattro
A8 98 Quattro
PASSAT 99 4 Motion, thru VIN 126366
8E0614111N ,8E0614111M , 8E0614111A ,8E0614111E
AUDIA4 99 Quattro (w/EDL)
AUDIA4 00-01 Quattro, w/o stability cntrl
AUDIA4 02 VIN mdl "D" (8th digit), Quattro,
w/o stability cntrl
AUDIA6 99 Quattro
AUDIA6 00-01 Quattro, Diff Lck (EDL)
A8 99 Quattro
A8 00-02 (Quattro), w/o Ele Stability Prog
A8 03 (thru 9/02), w/o Ele Stability Prog
AUS4 00-02 w/o stability cntrl
AUDIS8 01-02 w/o Ele Stability Prog
AUDIS8 03 (thru 9/02), w/o Ele Stability Prog
PASSAT 99 4 Motion, frm VIN 126367
PASSAT 00 4 Motion
PASSAT 01 thru VIN 049999, exc. Ele Stability
Prog; 4 Motion
frm VIN 050000, w/Ele Diff Lck (EDL)
AWD
PASSAT 02 w/o Ele Stability Prog; w/Ele Diff
Lck (EDL); w/o trac cont; AWD
8E0614111A,8E0614111E, 8E0614111N ,8E0614111M
AUDIA4 99-01 exc. Quattro; w/o trac control;
(w/EDS)
AUDIA4 02 VIN mdl "D" (8th digit), exc.
Quattro; w/o trac control; (w/EDS)
AUDIA6 99-01 exc. Quattro; Ele Diff Lck (EDL)
PASSAT 00 exc. 4 Motion; w/o navigation
system; w/o trac control; w/Ele Diff Lck
(EDL)
Prog; exc. 4 Motion; w/o navigation sys;
w/o trac cont; w/Ele
FWD
PASSAT 02 Assm, w/o Ele Stability Prog; w/Ele Diff
Lck (EDL); w/o trac cont; FWD
PASSAT 03-04 Assm, w/o Ele Stability Prog; w/o trac
control; w/Ele Diff Lck (EDL)
8E0614111B , 8E0614111F
AUDIA6 99 exc. Quattro; Trac Cont (ASR)
AUDIA6 00 exc. Quattro; Trac Cont (ASR), thru
VIN 015000
A8 98-99 exc. Quattro
cntrl (ASR); ID 8E0
8E0614111C, 8E0614111G
AUDIA6 01 exc. Quattro; Trac Cont (ASR)
cntrl (ASR); ID 8E0
w/trac cont (ASR)
Lck (EDL); w/trac cont (ASR)
PASSAT 03-04 w/o Ele Stability Prog; w/trac cntrl
3B0614111, 8E0614111AQ
AUDIA4 99-01 exc. Quattro; w/trac cntrl (ASR &
EDS)
Quattro; w/trac cntrl (ASR & EDS)
AUDIA6 00 exc. Quattro; Trac Cont (ASR), frm
VIN 015001
cntrl (ASR); ID 8E0
system; w/trac cntrl (ASR)
[IMG]local://upfiles/5546/D949F03E25264C15BC1529CEC3F43D0E.jpg[/IMG]
I have bad experience with their repairs[:@]. You repaired my module and this failure before one year, I sent it to you in guarantee and I had to pay all the shipment costs again.
You again repaired it bad and I had to pay all the shipment costs again!!!
One month has passed and you don't send my module and doesn't respond my mails!!!
I have all the documents and track number when you received my module
NEVER MORE I WILL REPAIR with AUTO & TRUCK ELECTRONICS
YOU THINK BEFORE REPAIRING WITH THEM :
- BAD REPAIR
- BAD CUSTOMER SERVICE
- IT DOESN'T FULFILL THE GUARANTEE THAT OFFERS
DON'T LOSE MONEY, TIME AND ABS MODULE
I had terrible experience with ATE (AUTO & TRUCK ELECTRONICS), that it doesn't happen to you!!
- BAD REPAIR
damn, i see these guys on ebay sometimes and i was thinking about checking out my abs module...i know one of my abs components is bad but i haven't been able to pinpoint it yet.
ORIGINAL: coheed
do you guys think that's why my abs light is on and my emergensy brake light is flashing? I have posted about it before, but no one told me about a bad abs modual.
^^^ It's telling you that your ABS is not working so be careful when you slam the brakes cuz ABS will not pump them for you. So to answer your question no, it will not hurt anything just use caution...........
if your in areas where you get bad weather like a lot of snow i'd think about getting it rebuilt. You can get a new module from the dealer but that will be in the thousands of dollar range. You can send it away and get it rebuilt like the guy is suggesting here. That's what I did in my 98 a4 and it worked fine after that.
