Audi Techs! Help!! P1545
Old Jan 30, 2007 | 05:03 PM
southcoast's Avatar
Default Audi Techs! Help!! P1545
I put my FMIC with 3" piping and I left a post about my car not starting, well I checked for codes and I got P1545 which has to do with the throttle body malfunction. I called my mechanic and he says the best thing to do is to reprogram the ECU because it might have lost communication with the ECU, he will do it for $80 but he says if that doesn’t work I will have to get a new throttle body or used for $170 but he will have to reprogram the computer again after installing the used one, IS THIS TRUE? What do you guys think, I did get the car running now and it idles OK but when I give it gas it is way behind and even backfires from the intake part.
A4 1999 1.8T B5
Old Jan 30, 2007 | 05:17 PM
techbod's Avatar
Default RE: Audi Techs! Help!! P1545
P1545 = throttle valve malfunction possible causes are sticking throttle valve or tight, wiring, throttle control
Old Jan 30, 2007 | 05:23 PM
southcoast's Avatar
so would i have to replace? and would it need to get reprogrammed or is my mechanic full of it?
Old Jan 30, 2007 | 05:27 PM
techbod's Avatar
your mechanic is full of it, the throttle body needs cleaning out so the butterfly valve operates smoothly ( probably carbed up a little ) then lets go from there
Old Jan 30, 2007 | 05:34 PM
techbod's Avatar
[IMG]local://upfiles/12092/4AC65806BC92462DAFFA1E92C961FC8D.jpg[/IMG]
southcoast's Avatar
i took it apart and cleaned the throttle body crystal clear and put it back with a new gasket and same thing happened. its weird, it sits at idle fine but when i try to rev it it lags bigtime and if i hold the gas pedal down the rpms drop down anyways so i have to keep pumping the gas for it to stay on and even has a backfire coming out of the intake and sometimes as im giving it gas over and over some pumps dont even rev up the engine
Old Jan 30, 2007 | 05:37 PM
techbod's Avatar
[IMG]local://upfiles/12092/91D927BF165E4523B68FF9BEFD38175F.jpg[/IMG]
Old Jan 30, 2007 | 05:41 PM
techbod's Avatar
well you mechanic just might be right on replacing the complete unit, my appoles to him/herbut things have to be tested before any statements are made which = $$$$££££ ask him to test the system by standard means like a volt meter
Old Jan 30, 2007 | 05:45 PM
techbod's Avatar
just one more thing ( you fitted a 3" intake pipe?? ) if so id the gasket catching on the throttle flap/ butterfly valve
Old Jan 30, 2007 | 05:48 PM
southcoast's Avatar
yeah, 3" piping, needed to trim down the S4 bumper i got but it doesnt look tacky (the bumper is fiberglass) and it happened before i removed the throttle body so im sure the gasket is not cought with the flap, i made sure it was secure.
