Audi Techs... Need Rear driveshaft Part #'s
Old Jan 28, 2008 | 04:02 PM
Papachristou's Avatar
Default Audi Techs... Need Rear driveshaft Part #'s
Need the rear driveshaft bolt part #s and torque specs if anyone has them for a 2004 b6 six speed... these are the six bolts connecting the rear driveshaft to the back of the tranny/torsen housing.. 6mm allen head i believe...
one of the techs here told me they were 1 time use stretch bolts along with the flywheel and pressure plate which i already have ordered
Old Jan 28, 2008 | 04:32 PM
cincyTT's Avatar
I'm make believe
Default RE: Audi Techs... Need Rear driveshaft Part #'s
Discription is above the number
6-speed manual gearbox / for 4 wheel drive / F >> 8E-3-500 000
1.8-3.0 ltr. / ENV,FPP,FTM, FTT,FRE,FYT, FYF,GBD,GBC, GBE,GBB,GDZ, HER
01E301103N[/align][/align]
transmission case
/ ENV,FTM,GBB
(1)
01E301103L[/align][/align]
transmission case
/ FPP,FTT,FRE, FYT,FYF,GBD, GBC,GBE,GDZ, HER
012301457C[/align][/align]
oil seal
16X24X6 /
01E301453G[/align][/align]
cover for gearshift rod
010409580[/align][/align]
round seal / switch for reversing light / see illustration:
919-40 /
N 90365907[/align][/align]
torx socket fillister hd. bolt
M8X22-E-W /
D 185400A2[/align][/align]
liquid sealant
10ML /
9
N 10037103[/align][/align]
sealing plug
M22X1,5 /
10
016311113B[/align][/align]
seal
11
012301143[/align][/align]
magnet
12
012301183A[/align][/align]
bush
14
01E301211C[/align][/align]
end shield / G >> 618925
(14)
01E301211G[/align][/align]
end shield / G 618926>>
(14)
end shield
/ GDZ,HER
16
012301473[/align][/align]
sleeve
12X30 /
17
N 90366001[/align][/align]
M8X36-E-PC /
18
01E301242E[/align][/align]
locking screw / screw / see illustration: / spring pin / see illustration:
311-92 311-92 /
21
01E301235[/align][/align]
gasket
22
01E301231AN[/align][/align]
gearbox cover
23
016301299[/align][/align]
dowel sleeve
24
N 90366401[/align][/align]
M8X60-E-PC /
25
N 0138441[/align][/align]
seal
A16X20X1,5 /
26
N 0161563[/align][/align]
sealing plug
M16X1,5 /
27
sealing plug
M22X1,5 /
28
084301143A[/align][/align]
magnet
29
01E311374[/align][/align]
support plate
30
N 90516701[/align][/align]
M8X141-E /
31
01E301276[/align][/align]
oil drip tray
32
089409069[/align][/align]
round seal
33
N 90545201[/align][/align]
round seal
107,54X3,53 /
34
01E301315A[/align][/align]
gear carrier
35
01E301307E[/align][/align]
balance weight
/ ENV,FPP,FTM, FTT,FYT,GBB, GBC
(35)
01E301307P[/align][/align]
balance weight
/ FRE,FYF,GBD GBE
36
M8X60-E-PC /
37
8D0301325B[/align][/align]
shield
39
N 10425101[/align][/align]
hexagon head bolt (combi)
M8X100X41 /
60
AMV18800102[/align][/align]
Old Jan 28, 2008 | 04:53 PM
N10332202 is the correct one i believe?
audi was kind enough to fax that same deal to me right after i posted that...
moneyfresh
Sep 3, 2012 04:53 PM
justinm001
Feb 22, 2010 10:45 PM
96audia4
Apr 25, 2009 05:02 PM
Artrip
Feb 1, 2008 11:47 PM
Artrip
Feb 1, 2008 11:42 PM
