autozone for coolant
Old Dec 8, 2007 | 02:24 AM
johnstef's Avatar
Default autozone for coolant
u think they will have coolant for audis????
Old Dec 8, 2007 | 02:34 AM
Bogie's Avatar
Default RE: autozone for coolant
They havea new Prestone that claims to be compatable with ALL coolant types.
Old Dec 8, 2007 | 02:39 AM
johnstef's Avatar
idk if i trust that ****
Old Dec 8, 2007 | 02:42 AM
Bogie's Avatar
That's your problem then. I put it in mixed with the red coolant, oh....60,000 miles ago at least with no problems. So you tell me....
Old Dec 8, 2007 | 06:58 AM
chaos92287's Avatar
mixing any coolant with g12 will cause problems, namely your thermostat getting stuck open
only place to get g12 is from the dealer or a shop that works on audi's
Old Dec 8, 2007 | 09:24 AM
CRAZYHAWK's Avatar
When the timing belt was done at 84K mi., the mechanic replaced
the G12 with universal global yellow antifreeze. I now have 134K mi.
with no problems.
Old Dec 8, 2007 | 09:54 AM
sineo's Avatar
You can buy fluid and replace the G12 with it, but don't mix it. You'll have to do a flush first if you buy another kind of fluid.
Old Dec 8, 2007 | 10:56 AM
onepoint8tee's Avatar
ORIGINAL: sineo
You are the smartest woman on AF, congrats:
Old Dec 8, 2007 | 11:13 AM
Bogie's Avatar
My T-Stat seems to be working just fine using the Prestone "universal" mixed with the Audi G12 coolant.
Old Dec 8, 2007 | 11:33 AM
ORIGINAL: Bogie
Its not a myth, G12 mixed with most other coolants will gel up.
