Sponsored by:
Sponsored by:
Axle shaft slides side to side... is it normal?
Old 10-05-2006, 12:20 AM
LoveMyAudiA4's Avatar
Default Axle shaft slides side to side... is it normal?
On my 96 A4 2.8l the front left(drivers side) axle shaft slides side to side about a 1/2" or so. the front right(passenger) side axle does not do this. I have also noticed that after driving a while the steering wheel will shake like the right front wheel will fall off. so i pull over and everything seems fine... then it doesnt do it for a while again. can this have somethine to do with the axle shaft or the control arms or tie rod? Is this normal?
Old 10-05-2006, 12:47 AM
Trey25's Avatar
Default RE: Axle shaft slides side to side... is it normal?
Certainly not normal. Check the gearhub to see axle bolt is tighten, check to see if any suspension parts are bad.
Old 10-05-2006, 11:21 AM
Axle bolt seems tight. Outer Tie-Rob is shot and the axle shaft is going to need to be replaced. I can take the wheel and shake it back and forth sid to side and the arm that the outter tie-rod is on that goes in the Rack n Pinion moves back and forth. I am going to repalce the whole rack but does this sound like just the tie-rod or something inside the rack?
Old 10-05-2006, 11:37 AM
CRAZYHAWK's Avatar
With 110K mi. , I had the outer tie rods replaced. It cost $450 including tax.
Use this link to find a good independent front end shop:
http://www.gsp9700.com/pub/search/findgsp9700.cfm
Old 10-05-2006, 08:08 PM
acetrebo's Avatar
Its just the tie-rod ends.
Replace those both DIY for $100. Get the upgraded myle ends.
Then if you still have play, look deeper, but this is a common issue for the symptom you are having.
You'll need an alignment afterwards, unless you carefully count the threads and put them back on just the same, you might get away with it. Normally you'll need it aligned though.
Old 10-06-2006, 12:07 AM
trailboss's Avatar
ORIGINAL: CRAZYHAWK
450.............. I did it in 45 mins both sides, thats crazy way to much.........
Old 10-06-2006, 12:19 AM
CRAZYHAWK's Avatar
outer tie rod ends 2 X 88.52 177.04
steering rack boot 2 X 15.76 15.76
clip 3 X 3.42 10.26
1.6 hours labor 1.6 X 79.91 127.86
four wheel alignment 69.00
tax 33.00
Old 10-06-2006, 01:07 AM
TDRILL's Avatar
If you are going to do inner and outer tie rod ends, think about buying mine, I have an extra set (2X inner and 2X outer) brand new with boots. They are the HD upgraded Meyle ones from ECS.
https://www.audiforums.com/m_358913/tm.htm
Zumajay
05-21-2015 09:05 PM
sbp82290
11-13-2014 04:08 PM
brewder
10-12-2014 08:12 AM
ejazmughal
03-29-2006 02:42 PM
jcrewhond
08-31-2005 02:13 PM
Quick Reply: Axle shaft slides side to side... is it normal?
