B&M headaches
Old Mar 21, 2007 | 01:24 AM
stacks's Avatar
Default RE: B&M headaches
You need to make sure it is in neutral when tou install it so there is no confusion as to where the stick needs to be.
Old Mar 21, 2007 | 02:30 PM
ErikCzajkowski's Avatar
i would rather have to pushdown, because with the 6-Speed since reverse is right next to first gear, when you go to select first gear and pull the stick to the left, there is no stopping point for you to know where first gear is, it will just go right into reverse.
which sucks because now that its shorter, reverse and first are very close together and if you arent careful you can put it into reverse instead.
i got some new retaining rings that may help hold the spring down better, and i'll redo the install friday when im off work. i'll be sure to have it in neutral
Old Mar 21, 2007 | 06:34 PM
swift_A4's Avatar
that does suck with a 6 speed i would want that stop there! Definatly! i hope you get it to work out.
Old Mar 22, 2007 | 01:02 AM
i'll give B&M a call too and see if they have any ideas or recommendations.
will let you guys know how helpful they are in terms of customer care, for future reference.
Old Mar 22, 2007 | 01:03 AM
Jeff's Avatar
Zombie Defense Force
sorry i didnt notice you had a 6 speed. then i would want push down also
Old Mar 22, 2007 | 01:21 AM
qUaTtRoA4's Avatar
yeah, you'd definately want a push down reverse, the gearbox is set up the same as the bimmers,and I have a friend who downshifted into "first" (reverse on accident) he was going about 20, he wanted to fishtail (euro-dift) through a right hand turn and instead the card slowed to a stop and stalled... about a month later his clutch went (he only got 30k out of his first...haha)....keep the push down reverse!
Tremar
Jul 19, 2012 12:38 PM
patrixx006
Mar 19, 2012 09:51 PM
viziers
Mar 25, 2006 02:31 AM
