B5 1.8T Engine Diagrahm
Old Apr 19, 2007 | 04:40 PM
jrodpikap's Avatar
Default B5 1.8T Engine Diagrahm
So, the previous version of this diagrahm I have is labeled all wrong, so I was trying to get this filled out right, i'll start it with the easy ones I know and hopefully with everyone's input, it can be complete (and correct) shortly. Thanks.[/align]
3)
4) 058 Check Valve
5) Airbox
6) K03 Turbo
7)
8)
9)
10) 058 Check Valve
11)
12) 058 Check Value
13)
14)
15) 058 Check Valves
16)
17) Intercooler
18)
19)
20) Intake Manifold
21)
22)
23) Diverter Valve
24)[/align]
Old Apr 19, 2007 | 04:51 PM
Lazer Viking's Avatar
Default RE: B5 1.8T Engine Diagrahm
3 another check valve
7 i belive is the coolant temp sensor
16 yet another check valve
18 throttle body
21(or 23) is the n75 valve
thats pretty much all i can identify
Old Apr 19, 2007 | 05:02 PM
jrodpikap's Avatar
I believe #23 is the n75 valve...thanks!
Old Apr 19, 2007 | 05:03 PM
jrodpikap's Avatar
Bump ^
Old Apr 19, 2007 | 05:26 PM
FASTER's Avatar
Tech Slut
8 is ur fpr(fuel pressure regulator)
aRIf's Avatar
21- Wastegate
23-dv
22-n75
Old Apr 19, 2007 | 06:01 PM
kpatz's Avatar
Ok, I found my Bentley manual page (for B6, I'll match up to your B5 diagram best I can)
Thing on the far left (unnumbered and cut off in your diagram) is the secondary air injection pump
3-EVAP purge valve (N80)
7-Combination valve for secondary air injection
9-Goes to brake booster
13-Secondary Air Injection Solenoid Valve
18-To EVAP leak detection pump
19-Recirculating valve for turbo
21-Vacuum diaphragm for boost pressure regulation
22-N75 (Wastegate Bypass Regulator Valve)
23-DV
24-Pressure regulator valve for crankshaft housing ventilation
Old Apr 19, 2007 | 06:03 PM
jrodpikap's Avatar
Nice work...
Old Apr 19, 2007 | 07:50 PM
jrodpikap's Avatar
Finished Version...if anyone is interested:
1)[/b] EVAP canister
2)[/b] From fuel tank
3)[/b] Evaporative Emission (EVAP) canister purge regulator valve (N80)
4)[/b] Check-valve for EVAP canister (between EVAP canister and intake manifold before turbocharger)
- Installation position (light/dark side): Arrow points in direction of flow, as shown[/i] -
5)[/b] Air Box/Intake
6)[/b] Turbocharger (Check boost pressure page 21-46)
7)[/b] Combination valve for secondary air injection (AIR)
8)[/b] Fuel pressure regulator (FPR)
9)[/b] To power brake booster
10)[/b] 058 Check valve
11)[/b] Vacuum booster
12)[/b] To Leak Detection Pump (LDP)
13)[/b] Vacuum reservoir
14)[/b] Distributor piece
15)[/b] 058 Check valve
16)[/b] Secondary Air Injection (AIR) solenoid valve (N112)
17)[/b] Crankcase vent
18)[/b] 058 Check valve
19)[/b] To tank Leak Detection Pump (LDP) (V144)
20)[/b] 058 Check valve
21)[/b] Intercooler w/charge air pressure sensor (G31)
22)[/b] Throttle Body (valve control module) (J338)
23)[/b] Reticulating valve for turbocharger (N249)
24)[/b] Intake manifold w/Intake Air Temperature (IAT) sensor (G42)
25)[/b] Pressure unit for boost pressure regulation (Wastegate Actuator?)
26)[/b] Wastegate bypass regulator valve (N75)
27)[/b] Mechanical recirculation valve
28)[/b] Pressure control valve for crankcase ventilation (Crankcase Breather)
29)[/b] Secondary Air Injection (AIR) pump motor (V101)
Old Apr 19, 2007 | 08:16 PM
techbod's Avatar
Default RE: B5 1.8T Engine Diagram
EGR system total sh*t ill do a how to get rid of it one day and its not that hard
