Are B5 tape players and cd players swappable?
Old Sep 12, 2006 | 03:48 AM
One.EightT's Avatar
Default Are B5 tape players and cd players swappable?
Just bought a 98.5 A4 1.8tqm a couple of days ago and it has a radio with only a tape player. Is it possible to use another B5 cd player and place it in place of my tape player? Will it be plug and play? If not, how would I do it?
Old Sep 12, 2006 | 02:52 PM
One.EightT's Avatar
Default RE: Are B5 tape players and cd players swappable?
^^^ Anybody have any idea?
Also if I wanted to keep my original tape player/radio, could I just connect a CD changer to it??
Old Sep 12, 2006 | 02:53 PM
flyboy's Avatar
most of these types have a six disk changer in the back. look into that, or phat noise, now those are cool.
Old Sep 12, 2006 | 04:36 PM
wood_e's Avatar
I would assume that they are interchangeable if they are factory units.
Old Sep 12, 2006 | 04:41 PM
smokeU's Avatar
as long as you have the code. still not sure though the wiring diagram has something titled CD Gnd or something I'm wondering if it would work. it sounds like the previous owner took the changer out of the trunk?
Old Sep 12, 2006 | 05:00 PM
wood_e's Avatar
The CD changers go for about $100 on ebay, so if the PO didn't use CDs then he'd pocket $100
Old Sep 12, 2006 | 06:59 PM
sheek's Avatar
Can anyone answer this question from actual personal experience? I'd like to know also seeing as my 98 audi came with a tape deck. So you guys say "look into a cd changer off ebay" but what am I supposed to do with a stock cd changer if I have a stock tape deck? How is the tape deck supposed to interact with a cd changer when it has no cd controls? Does the cd changer come with it's own control unit or what?
Old Sep 12, 2006 | 08:22 PM
Ford2Audi6's Avatar
Yea, I had the same problem with my 99. The cd changer should be on the side of the trunk and if you pull the mat up a little you should see a chord which was for the six disc changer. In my case I am probably going to go aftermarket cd player because mine was not the bose system.
Old Sep 12, 2006 | 11:24 PM
sheek's Avatar
ORIGINAL: Ford2Audi6
So you're saying the cd changer u baught works fine with the stock tape deck you have and all you had to do was mount it in the trunk and plug it into the cable?
Old Sep 14, 2006 | 02:32 PM
One.EightT's Avatar
Ok, so if you're looking inside your trunk, will the cd changer connections be on the left side or right side? Thanks in advance.
