B6 TIPCHIP!!!!!!!!!!
Old Dec 7, 2006 | 07:03 PM
Genix's Avatar
Default RE: B6 TIPCHIP!!!!!!!!!!
What exactly is a tip chip?
Old Dec 7, 2006 | 07:09 PM
JP A4's Avatar
um test pipe sounds like a good idea, might want to get a muffler lined up too. DO NOT change injectors unless you are getting it chipped for that size of injectors. AWE knows alot they seemed very informational when i called. but bigger injectors on your stokc ecu will just **** it up, the ecu reads in voltage or pulses, bigger injectors could have same pulse and put out 2 times the fuel, or maybe even 1/2 the fuel its suppose to, anyway
Old Dec 7, 2006 | 07:11 PM
akielb's Avatar
OMG!!! - well I'll answer you before you get flamed
OK so first go to AWE Tuning and check it out - if you still need help do some searching
TheJazz7's Avatar
ORIGINAL: Genix
All the answers you need are right here:
https://www.audiforums.com/search.asp
Old Dec 7, 2006 | 07:16 PM
akielb's Avatar
ORIGINAL: JP A4
read his sig - he already has an exhaust and he's GIAC chipped for 93 does he need a special program to run injectors even with a chipped ECU?
Old Dec 7, 2006 | 07:17 PM
audiant's Avatar
lol yea that was a preety bad question the name is self explanitory. um i called awe and they told me to search what injecters to get for my car but they had software for the injectors i DEFINATLEY wasnt planning on doing injectors w/o the software.
BY THE WAY AWE WANTS 800 DOLLARS for the big injector flash!
Old Dec 7, 2006 | 07:18 PM
onepoint8tee's Avatar
ORIGINAL: audiant
Ya but the big injector file puts you at or near k04 power, and $800 is less than an actual k04 setup.
Old Dec 7, 2006 | 07:19 PM
  #18
audiant's Avatar
yea u need the injector flash
Old Dec 7, 2006 | 07:22 PM
  #19
audiant's Avatar
yea i hope it does put near k04 power cuz then that will hold me off for a little as far as power. However, im a chicken sh*t and im to scared to do a k04 set up on my tip tranny. i know some ppl do run k04's on tip trannys but idk im just to scared that something will go wrong since it wont be able to handle the power
Old Dec 7, 2006 | 07:23 PM
  #20
akielb's Avatar
ORIGINAL: audiant
Is that $800 if you don't have their software or is that the upgrade charge - they don't even charge that for the K04 upgrade flash - I called them and they said $600 as a first flash cost $-200 if you have their software.
AWE raping everyone lately!!!
