B7 A4 2.0t
Old Mar 13, 2006 | 04:19 PM
bluovalguy's Avatar
Default RE: B7 A4 2.0t
Gotcha. Just curious.
Old Mar 13, 2006 | 04:24 PM
viziers's Avatar
Member
I am however going to get a chip probabbly the GIAC chip seeings how there is a dist here in NC. ANd yes it will be the x-chip..
Old Mar 13, 2006 | 06:36 PM
liquidxit2's Avatar
I would go apr on a b7 I saw a write up where it had the best gains
Old Mar 14, 2006 | 12:12 AM
Jestnomen's Avatar
6th Gear
Plus they have the password lockout 91, 93, and 100 octane programs!
Old Mar 14, 2006 | 10:10 AM
viziers's Avatar
Member
Bad news..... for the fuel pump i have the old one part # 06F127025B so my chip options are limited until i can figure out some wayto get the FP changed under warranty by audi..... Any ideas anyone???
Old Mar 14, 2006 | 11:06 AM
Jestnomen's Avatar
6th Gear
APR doesn't say anything about which fuel pump you need does it?
Old Mar 14, 2006 | 11:54 AM
viziers's Avatar
Member
ORIGINAL: Jestnomen
No APR does not mention anything about the FP issue but here is the link for the GIAC and what they say about the issue.
http://www.awe-tuning.com/pages/shar...hips&IL=b7chip
And for those of you who are lazy and dont want to go to the site here is some of the info from the site.. HEHE...
*** Special Note Regarding Fuel Pumps on the 2.0T: There is some debate regarding the performance effects of the high pressure fuel pump, found in the engine bay and required to produce the extremely high fuel pressures of the FSI system. The factory has superceded the high pressure pump part number from 06F127025B to 06F127025F. There is no definite cutoff date when cars began coming equipped with the 06F127025F part number, and the only real way to tell which pump your car has is to remove the engine covers and look at the part number on top of the high pressure pump. On the B7 chassis A4, the pump is located near the firewall at the end of the fuel rail as in the below picture. On all other 2.0T cars, it is found at the end of the fuel rail towards the driver side front of the car.
If your vehicle is equipped with the old part number pump 06F127025B, we recommend using the Sport Flashloader chip program available for your vehicle to prevent surging issues, especially if you have an aftermarket high flow cat. GIAC has done extensive testing on multiple 2.0T vehicles and has found a correlation between surging with higher boost levels with the old pump number. If your vehicle is equipped with the new part number pump 06F127025F, you can opt for the X-Chip Flashloader file, no matter what exhaust system is used.
If your vehicle is equipped with the old part number pump, there are very limited new part number pumps available for purchase at this time. There is also the possibility of getting the new pump installed under warranty free of charge. Contact your VW/Audi dealer for more information.
Old Mar 14, 2006 | 03:42 PM
  #18
viziers's Avatar
Member
Hmmmm no feedback?? Lol...
Old Mar 14, 2006 | 03:49 PM
  #19
Jestnomen's Avatar
6th Gear
Yeah there were independant testing of the fuel pumps done on Audiworld. I'll see if I can dig it up when I get home from work.
Old Mar 14, 2006 | 03:57 PM
  #20
viziers's Avatar
Member
ORIGINAL: Jestnomen
Cool thank you chip is on hold for now until either i can get pump changed under warranty or if i have to shell out the cash to do it myself.....[:@]
