B7 Test pipe Video
http://smg.photobucket.com/albums/v4...A4Testpipe.flv
My A4 with an Eurocode testpipe together with Revo stage 2, it is from the inside of the car.
FUQ YES!
That launch action at around the 2 minute mark was hot!
Still watching. Will be back for a final review - I just had to comment.
And THANKS for finally having someone get a B7 Testpipe video up.
***OK, just finished watching. Whoever it was that said the testpipe for a B7 sounds like, "ISH" is an idiot.
In my opinion, it sounded awesome and the video sequence of the run after the launch was some of the cleanest video of a quick Audi that I've seen.
VERY NICE little write up......er.....film up of your car and what it can do.
Thanks again for posting. By the way, I have the DVFSiT valve in and it sounds awesome.
I tried to take video / audio of it, but the tiny mic in my digital camera is drowned out by the sound of the RPMS.
When the whoosh finally comes, it's muffled and all you hear is the rev.
Gotta' find a better source for audio of it, but I'll throw it online eventually.
Ciao. Nice job.
Ciao. Nice job.
New Sound Clip from my car reving @ N
http://smg.photobucket.com/albums/v4...estpipeRev.flv
evoic
How does your car behave with the RS4 sway bar(s) I want to correct the under steer on my car without making it to twitchy, I was leaning towards the S4 rear sway bar.
Did you install the Sway bars?
What did you need?
What did you need?
I just took the 30mph merge curve before you get to my house at 75mph without making the ESP blink, you tell me how it handles.
I would go with the RS4 instead of the S4.
If you're going to upgrade, then get the most for your money - there's very little price difference between the two if memory serves me right.
A4....................16mm
Sport Susp........18mm
S-Line...............18mm
S4....................20mm
Neuspeed..........21mm.....$290
RS4..................22mm.....$145
H-Sport(A4).......22mm.....$430 w/ 35mm front ASB
H-Sport(S4).......24mm.....$430 w/ 35mm front ASB
As for the install, you just undo the bolts from the exhaust and let it drop down to the hangers. Unbolt the old sway, replace the bushings, rebolt the new one and replace the exhaust.
It's fairly simple, but I had Mike at PureMS do mine because he was already doing the Forge valve and he had it up on the lift.
If you have a ramp + jackstands, it's a do-at-home job.
If not, a tuner shop shouldn't charge more than $25-$50 for the install, tops.
Good luck.
Good luck.
greenday
Nov 29, 2005 03:43 PM
