B7 Using Oil??
Old Sep 12, 2007 | 08:15 PM
iamfranswa's Avatar
Default B7 Using Oil??
I searched the site but nothing really seemed to be exact, so here goes.
I have aB7, 2.0T, Stick car. It consistently uses 1 quart of oil in 1000 miles, nothing visible, no performance issues. It has under 10,000 miles on it. The dealer says that is normal. I have a neighbor with the same identical car, a few months older, and it uses no oil even in 10,000 miles. So, is it normal and my neighbor is lucky, or is it abnormal and I am not being told the truth? I have never honestly heard that this car would use oil. I know many american cars do.
Thanks in advance!
Old Sep 12, 2007 | 08:18 PM
cincyTT's Avatar
I'm make believe
Default RE: B7 Using Oil??
It being normal is BS, take to them and have it fixed. This shouldnt be your problem to fix on a new car
ocadam's Avatar
I have a B7 and i havent seen a drop of oil on the ground and my oil sensor is saying its low. I think the dealer is giving you the cold shoulder.
Old Sep 13, 2007 | 08:34 AM
david9999's Avatar
No car should use the amount of oil. My B5 has 185K miles and I use a quart every 4K miles.
I know where my oil is going: 1: Oil pan leak for last 120K miles. 2: turbo bearing starting to go.
Old Sep 13, 2007 | 11:38 AM
iamfranswa's Avatar
I sort of agree, I don't know anyone with a new(er) audi that uses oil... I think the dealer knows it is a lease car and they are just avoiding me on it.
Old Sep 13, 2007 | 01:24 PM
kextyn's Avatar
Tell the dealer to fix it, take the car back with a refund, or give you another one.
I don't know how it works for lease cars, but this should fall under lemon law for a normal purchase. Basically the dealer is refusing to fix the defect under warranty.
Here's part of the CO lemon law (just picked a state at random):
If the manufacturer, its agent, or its authorized dealer is unable to conform the motor vehicle to the warranty by repairing or correcting the defect or condition which substantially impairs the use and market value of such motor vehicle after a reasonable number of attempts, the manufacturer shall, at its option, replace the motor vehicle with a comparable motor vehicle or accept return of the motor vehicle from the consumer and refund to the consumer the full purchase price, including the sales tax, license fees, and registration fees and any similar governmental charges, less a reasonable allowance for the consumer's use of the motor vehicle.
- http://dealerselect.com/lemon/lemonbystate.html
FWIW my car is a 2001 1.8T and I never notice it losing oil. Every time I check it it's at the same spot on the stick.
Old Sep 13, 2007 | 01:41 PM
iamfranswa's Avatar
Since with an Audi lease, the car is technically owned by Audi, they have a vested interest in the car being right, I would think. Why would the dealer care, it has a problem and they get paid warranty to fix it no matter who owns it.
I am not a high mileage driver, but if I was, say 30,000 miles a year, that is a quart of oil every 12 days (or 1000 miles) in my case. That is just silly.... who buys an Audi expecting to add their own oil every 2 weeks.
Old Sep 13, 2007 | 01:55 PM
onepoint8tee's Avatar
You need to talk to AOA.
Old Sep 13, 2007 | 05:09 PM
auditech79's Avatar
Change the pcv valve, the 2.0T engine on the A3 seems to burn that amount of oil a lot more commonly now around the 20k mark, and its now starting to happen on the A4. It wouldn't suprise me if they release an updated pcv valve soon.
The only reason the tech didn't want to work on it is he is required to do an oil consumption test which is a huge pain in the *** and Audi won't pay him a cent for doing it either. It requires draining the oil and taking off the old filter, weighing it then putting it back into the car. Then you would drive it for 600 miles or more then take it back to the dealer. He then does the entire procedure again and measures the difference in weight. If its outside specs then he can now diagnose the problem, but not before.
Its a huge pain the *** for both of you, so you're better off just replacing the pcv valve by yourself because he HAS to do the procedure before replacing the pcv valve or he gets his peepee wacked by audi.
Old Sep 13, 2007 | 05:22 PM
hiwords's Avatar
if u have a dog, sick it on the person at audi who told u that. that's total BS. if they still say no, i believe there's a number u can call that goes to audi headquarters and they'll make sure the dealer fixes it. basically jsut make a big scene. lol
