back firing?
Old Oct 10, 2006 | 04:09 PM
freak162's Avatar
Default back firing?
hey i owe a 2004 a4 with evo intake and magnaflow exhaust. my problem is wen iam using the tiptronic and are in like 5 or 6th gear and floor it my car kinda hesitates and sounds like it back fires and ideas why or whats wrong?
Old Oct 10, 2006 | 04:38 PM
smokeU's Avatar
Default RE: back firing?
do you have a mid muffler?
Old Oct 10, 2006 | 05:30 PM
donsajid's Avatar
have you tried using any injection cleaner? I had a similar problem on a 2.5tdi and it was doing also doing it in the upper rev range. poured the injection cleaner in and the problem has been solved.
Hope that helps.
Old Oct 10, 2006 | 09:59 PM
david9999's Avatar
Sounds like you are running rich. Check for codes even though the check engine light isn't on.
Old Oct 10, 2006 | 11:01 PM
freak162's Avatar
i have the full magnaflow exhaust so i do beleive it included mid muffler. but wat cleaner do you recomened or should i get the dealership to look at it?
Old Oct 10, 2006 | 11:27 PM
david9999's Avatar
Don't take it to the dealership. Go to an Autozone and ask them to scan it for codes. Post them back here.
When you floor the car, does the transmission downshift?
Old Oct 11, 2006 | 12:53 PM
freak162's Avatar
yes wen i floor it the car does down shift then hesitates and back fires. does it cost anything to get it scaned?
Old Oct 11, 2006 | 01:14 PM
aRIf's Avatar
Check for a leak on your system between from airfilter to turbo. if there is a leak, you will deff. run rich.
you can use seafoam to clean your injectors. you can find it in any auto store.
Old Oct 11, 2006 | 01:18 PM
techbod's Avatar
as requested before did you remove any silencers / mid resonator box, what type of system do you have???
Old Oct 11, 2006 | 02:07 PM
freak162's Avatar
i have the cat back exhaust from magnaflow but ill check the intake thanks
rickyates100
S8
Apr 23, 2015 03:43 PM
Dclem
May 3, 2014 01:11 PM
LinziB75
Jan 15, 2010 04:15 PM
Albee G
Apr 23, 2008 05:07 PM
auditurbo381
Mar 30, 2008 06:03 PM
