Battery Removal and Install
Old Jan 29, 2008 | 09:23 PM
audi_n00b's Avatar
Default Battery Removal and Install
Tomorrow I'm going to be removing my old batter and installing a new one. Anyone done this on a 2000 A4 1.8TQM? I've never installed a car battery and could use some advice. I searched and couldn't find a writeup or anything so some help would be appreciated.
Old Jan 29, 2008 | 09:32 PM
hiwords's Avatar
Default RE: Battery Removal and Install
you need a 8mm, a 10 or 12 mm and a 6" extension. then just take out and put in. there's a thing in the front of the baterry hold ing it down. make sure to have yur radio code or plug in a 9v battery into the cig outlet.
Old Jan 29, 2008 | 09:50 PM
manufan's Avatar
Before you loosen the piece that holds down the edge of the battery, givethe bolta spray with your favorite lubricant. If you don't have a favorite, use PB Blaster. Negative cable comes off first, identified by the negative sign on the battery and black colored cable. Next, take off the positive cable, identified by the positive symbol on the battery and the red colored cable. Once the cables are off, loosen the bolt that you sprayed and remove the hold down clamp. Observe which way the clamp sits so you can replace it in the same position. Replace the cables onto the new battery. First, tighten thered to the positive and then black to thenegative. Tighten the clamps so they're tight, but don't over-tighten. You should not be able to twist the terminal on the battery post. When you replace the negative on the battery(positive is already on) you might observe a small spark. Nothing out of the ordinary. As hiwords stated: before you begin, be sure you have the code for your radio.
Old Jan 30, 2008 | 12:31 AM
dankhound's Avatar
Theres a vent tube on the drivers side of the battery too. It just pulls out. When connecting the negative cable its not a bad idea to turn your head away. That spark mentioned above can cause the battery to explode. Its like a 1 in a millionchance but id rather not get battery acid in my eyes.
fusion28
Apr 10, 2012 04:29 AM
LT1FirebirdSLP
Oct 7, 2008 03:33 PM
KylesA4
Mar 19, 2008 10:24 AM
sburd
Dec 1, 2006 10:23 AM
russell_s
Jun 15, 2006 07:38 PM
