belt, an control arms.
Old Aug 29, 2007 | 06:39 PM
Slowb5's Avatar
Default belt, an control arms.
99 1.8T fwd...belt's squeaking in front...easy to replace? and control arms are bad.front passenger side...how do i find out which one in particular. tests...
thx all.
Old Aug 29, 2007 | 07:18 PM
2k S4's Avatar
Default RE: belt, an control arms.
Yes, the belt is easy to replace, well easy for an Audi. Do all the arms.
Old Aug 29, 2007 | 07:33 PM
Adam@mvp's Avatar
If you have access to a lift just see if you can look at the bushing etc listen for a squeak if you can move it and you should be able to fix the problem!
Belts are cheap and easy to replace if you have any knowledge on working on a car.
Adam~
Old Aug 30, 2007 | 06:27 PM
Slowb5's Avatar
well yeah, i was just curious as to the general do it. unloosen....replace...retighten.
all the arms....indeed. how about a lil more specific on the belt. how do i get at it. its deep behind that ****.
Old Aug 30, 2007 | 08:52 PM
david9999's Avatar
Which belt do you want to replace, serpentine or iming?
Control arms often are rusted in place. You may need a torch to get them unstuck. I you replace them you willl need an alignment. If you are doing the control arms, might as well do the outer tie rods too.
Old Aug 30, 2007 | 10:58 PM
Slowb5's Avatar
tie rods on both sides done...just lookin fer the control arms...
and im not lookin fer the timing belt...just the serpentine, its makin gnarly squeaks *lookin down the front the motor* on the lower left side...especially when the a/c's on.
Old Aug 31, 2007 | 12:29 PM
Adam@mvp's Avatar
Go to www.eurospecsport.com and look at the kit that they have in suspension. I think you might like it!
Adam~
Old Aug 31, 2007 | 07:20 PM
Slowb5's Avatar
adam, you are...the most valuable player....good lookin out man!
Old Aug 31, 2007 | 07:47 PM
Adam@mvp's Avatar
haha thanks! I always try to help as much as I can. Did that help on what you needed? Let me know if I can further help you!!
Adam~
Old Sep 1, 2007 | 11:51 AM
Slowb5's Avatar
well, what should i loosen to get ac belt off, its the one squeakin, and i got the replacement, jus no idea what to loosen to get that pos belt off?? i could cut it, but gettin the new one on is the deal....
