Big Engine Trouble
Old Sep 26, 2006 | 03:14 AM
Johnnyd3689282's Avatar
Default RE: Big Engine Trouble
Thanks youll, im gonna do the alternator and the battery and get the scan done to see why im leaking random fluid
Old Sep 26, 2006 | 12:03 PM
tatman9999's Avatar
THE CHECK ENGINE LIGHT WILL COME ON CODE LOW VOTAGE.ABS LIGHT WILL COME ON TO.REPLACE YOUR ALT .IT WILL FIX ALL YOUR PROBLEMS.
Old Sep 26, 2006 | 04:43 PM
ok now my other question is should i have a random fluid leaking??? Because it wasnt until this happened that it sarted leaking???
Old Sep 26, 2006 | 05:57 PM
CRAZYHAWK's Avatar
Make sure the alternator belt is tight. Ask the place you intend to by the battery
from, to check the charging system.
Old Sep 26, 2006 | 09:41 PM
so if the alternator belt isn tight, will that cause me to leak fluid
Old Sep 26, 2006 | 10:51 PM
Well now i have another question. Who is the best company to buy a 180-200 Amp alternator from, i tried searching, and couldnt find many good results.
Old Sep 26, 2006 | 11:42 PM
CRAZYHAWK's Avatar
Loose belt causes the battery to discharge.
If the alternator is bad, have an independent shop change it.
Old Sep 27, 2006 | 12:08 AM
  #18
the only thing is with the stereo equipment that i am running, i need a big alternator, and a nice aftermarket alternator, and i dont know where to look for one at, because all of the shops that i called are saying the biggest they have is 140 maybe 160 amps. I need a big one, because of the car audio im running. i need one thats about 200 amps minimum.
Old Sep 27, 2006 | 12:38 PM
  #19
CRAZYHAWK's Avatar
2,400 to 2,800 watts. What kind of power does this amp need? Back in vacuum tube days with waisted
heat, this much power wasn't needed.
Old Sep 27, 2006 | 11:02 PM
  #20
Its more like Amps, i only had one hooked up. 1000/1 are the number one power draining amps. Im going to be running 2 1000/1 300/2 300/4. So 4 amps that equals 2600 watts. 1 1000/1 drained this alternator like nothing. It will be 2 2 farad caps, crossovers, EQs, 5 monitors, and 2 Yellow Top optimas. with 0 Gauge Wire. its a big hull for a shitty alternator.
