Bite the Bullet??
Old Nov 4, 2007 | 11:16 PM
kolbs_91's Avatar
Default Bite the Bullet??
I was gonna wait until the warranty ran out next summer to do the timing belt, but ECS has a complete kit on sale for $345 that includes everything listed.[*]Timing Belt[*]OE UpdatedTensioner[*]OE Tensioner Roller[*]OE Idler Roller[*]Hepu OE Water Pump With gasket[*]OE Thermostat with O-ring[*]A/C Belt[*]P/S Belt[*]Alternator Belt[*]ECS Lightweight Crank Pulley
I'm starting to consider just going ahead and getting it over with. What do you guys think??
The car's got 68k miles on it, by the way.
Old Nov 4, 2007 | 11:41 PM
ocadam's Avatar
Default RE: Bite the Bullet??
Its always good just to get it done to be safe. Im not sure is if thats everything it might or it might not but good luck.
Old Nov 4, 2007 | 11:46 PM
sean1.8t's Avatar
don't get the lightweight crank pulley. it is a waste of money. you wont notice a difference, and it has been known to cause problems. or at least believed to be the culprit. basically our engines are internally balanced. and lessening the weight off of that part of the crank is believed to throw the engine out of balance..
this is the kit i got---->http://www.purems.com/products/product.php/II=1151. around $280 out the door and it has everything you'll need
make sure you click on the dialog box and select the complete kit. which add's ~$86
Old Nov 5, 2007 | 02:54 PM
kolbs_91's Avatar
Thanks for that link, man. I'll probably go ahead and order that oneand get it done before it's winter. Looks like it's a pretty good kit.
jagtoes
B7 Models
May 22, 2012 06:48 PM
iammrbenn
Aug 13, 2011 07:45 AM
burtonboarder84
Mar 21, 2010 03:28 PM
bigern45
Apr 15, 2009 12:57 AM
AudiTim
Jun 16, 2007 10:38 PM
