Blow off Valve?
Old Feb 1, 2005 | 07:14 PM
  #101
Jestnomen's Avatar
6th Gear
Default RE: Blow off Valve?
Yes the air does lean out the mixture, but it is not to be considered "exta". The ECU has calculated it in already. Also I was thinking when you took your a/f ratio readings, you are suppose to read them at wide open throttle (WOT). The blow off valve/dv would not even factor in until you released your foot off the gas (a normally rich period anyways) compounded by the lack of additional air from the BOV).
Old Feb 1, 2005 | 07:17 PM
  #102
David_K's Avatar
rethink that bro. if th bov doesnt effect the fuel mixture at wot then it seems there is no problem with a bov. if that thinking were true it would explain the normal a/f readings
BTW we agree to disagree right?
  #103
Jestnomen's Avatar
6th Gear
ORIGINAL: David_K
the ecu is smart thats how it was built. yes it takes time (like 2 months) but it wont cause enough damge to destroy o2 sensors or foul the plugs unless the plugs and o2 sensor were getting close to needing replaceing.
The ECU takes approx 200 miles to learn itself.
Old Feb 1, 2005 | 07:19 PM
  #104
David_K's Avatar
yeah and it takes about 2000 miles to foul things at that minimal of a ratio change. dont you think. i dont think the bov makes that big of a difference in the mixture. do you? were not recycling that much air.
Old Feb 1, 2005 | 07:23 PM
  #105
Jestnomen's Avatar
6th Gear
No not THAT much. It would take thousands of miles to make a difference.
You're right the BOV has no bearing on WOT conditions. It is when you release the throttle. Just because it isn't at WOT doesnt mean the engine isn't still burning fuel/air or combustion isn't taking place.
  #106
sfordeso's Avatar
...somehow i forgot about the ECU learning...
thanks jest
Old Feb 1, 2005 | 07:25 PM
  #107
David_K's Avatar
yeah you prbably forgot cuz you drive a ford.
and yeah the a/f mixtures wouldnt be affected under part throttle cuz the bov is closed. the only time it would run rich is the slight fraction of a second the bov is open. then all is well. catch my drift?
Old Feb 1, 2005 | 07:27 PM
  #108
Jestnomen's Avatar
6th Gear
Hey if you do a lot of city driving, that fraction of a second can add up.
Old Feb 1, 2005 | 07:29 PM
  #109
sfordeso's Avatar
fords do the same thing...but yeah, i'll be willing to bet it's not as advanced.. it's close
  #110
David_K's Avatar
but not enough to cause any damage to the engine. i see how making the one mod you do a bov would mess it up. the stock plugs would foul but if you got better plugs that ignite the mixture better then there would be no left over unburned gasoline. plus a bov sprays all the oil fronm the intake into the air.
