Blown speaker, passenger door
Old Oct 29, 2006 | 05:10 PM
portwolf's Avatar
Default Blown speaker, passenger door
Does anyone know what size the lower speakers are in the front doors on a 99 A4?
I need to replace it and i'd like to order some online before i take the door off.
Old Oct 29, 2006 | 06:29 PM
Lazer Viking's Avatar
Default RE: Blown speaker, passenger door
4"
the rear are 6.5" just uncase you feel like getting all new speakers
search for these easy things next time
Old Oct 29, 2006 | 06:57 PM
BadLuckAudi's Avatar
do you have bose?? cuz its a bitch to fin speakers that are compatable
Old Oct 29, 2006 | 11:58 PM
onepoint8tee's Avatar
just so you know, this is very common. Its a bad woofer design (dual voice coil)
The 2nd voice coil is used for the intigrated phone. So if you have a phone hooked up to the jack in your armrest that speaker is where you would hear the speakerphone from. Mine is blown, and so is everyone elses (mostly.) Fortunately, this doesnt really affect sound quality at higher volumes and is only really noticeable at very low volumes with high bass.
Old Oct 30, 2006 | 12:04 AM
well that explains why it only sounds like crap comming from that door, whatever new speakers when i get a new job
Old Oct 30, 2006 | 12:31 AM
chaos92287's Avatar
umm...im pretty sure the speaker is 5 1/4" not 4"
Old Oct 30, 2006 | 12:41 AM
really ?...i could have sworn is was 4...probably mistaken then
Old Oct 30, 2006 | 12:51 AM
chaos92287's Avatar
souddomain says they're 5 1/4" and if my memory serves me right the best buy computer says the same...assuming the speaker sizes are the same for the dif. stereos. for reference i got a 98 with the bose concert sound system.
Old Nov 2, 2006 | 07:21 PM
ugcpower.com's Avatar
Bestbuy is garbage =p. And yes, they are 5 1/4" speakers in the lower door. The only reason it is hard to install aftermarket speakers is because of the amp bypass you have to perform if you have the bose system.
Old Nov 2, 2006 | 09:13 PM
jrodpikap's Avatar
Check Crutchfield.com for the size and comparable replacement models...they have some sort of a bracket to make most brands fit...although they can be pretty damen expensive...
