Blue Smoke
Old Jan 6, 2005 | 10:43 PM
CaliA4's Avatar
Default Blue Smoke
When I start the car in the morning (I live in sunny California so its never that cold) it spits out blue smoke. I've owned this car for not even 2 weeks and I am starting to think that I should have stuck to my 96 C220...
Old Jan 6, 2005 | 10:49 PM
JDCrowe's Avatar
Default RE: Blue Smoke
check for a smurf in the muffler
Old Jan 6, 2005 | 10:50 PM
Jestnomen's Avatar
6th Gear
Well It could be leaky valve seaks. The oil leaks into the combustion chamber while it is sitting, and when you start up it is burning off. How many miles does your car/what year? Please include specifics here when you ask questions.
Is your oil overfilled?
Old Jan 7, 2005 | 12:16 AM
CaliA4's Avatar
Sorry about that...the car is a 96 A4 2.8Q with 120K miles.
Old Jan 7, 2005 | 12:39 AM
Jestnomen's Avatar
6th Gear
Better get your car into the shop, and monitor the oil level untill you can. Sad to say if they don't fix this for you, it will probably be an expensive one. [:@]
Old Jan 7, 2005 | 12:42 AM
CaliA4's Avatar
This happens only in the morning while I get it warmed up, it disappears afterwards.
Old Jan 7, 2005 | 12:45 AM
Jestnomen's Avatar
6th Gear
Right I already explained why this happens only when you have a cold start. Over night the oil has had time to leak through the leaky valves and pool in the combustion chamber. When you start the car up it is immediately burned off. Oil creates blue smoke when it is burned. Once the car is warmed up there is not a substantial amount of oil burning to create any more blue smoke, even though you are probably still burning small amounts.
Old Jan 7, 2005 | 02:16 AM
CaliA4's Avatar
How do I go about fixing this and how much will it cost me?
Old Jan 27, 2005 | 05:34 AM
Narcissus's Avatar
Ah, did some searching and found this.
Are valve stem seals all I need? 20 of these: Valve stem seal link
Did this a while back on a different car, I'll at least definitely need a special tool, though.
I just ordered the Bentley CD along with the air, fuel and ACC filters, so I guess I'll find out soon enough. Anyone know a good source for special tools? I can't seem to find any. []
DDonG
Oct 20, 2019 10:29 AM
scottmo
Apr 20, 2014 02:17 PM
mattk45
Mar 6, 2012 06:02 PM
eddo
Feb 20, 2009 11:18 AM
mrdb85
Jul 16, 2007 12:02 PM
