Boost fall off
Old Nov 5, 2006 | 02:47 AM
AudiTurbo's Avatar
Default Boost fall off
Hey i have a 98 a4 with the giac chip, n75j, k&n filter, and forge dv valve. When i get on it in first it hits about 10psi, 2nd it goes to about 15psi and falls off(sometimes fast), and in 3rd it goes up to about 18, and then falls off again......what do you all think?
thanks!
Old Nov 5, 2006 | 02:50 AM
Jeff's Avatar
Zombie Defense Force
Default RE: Boost fall off
small turbo running out of breath. get a larger turbo and that wont happen
Old Nov 5, 2006 | 02:52 AM
AudiTurbo's Avatar
what are the k03 suppost to fall off to with the giac chip?
Should It hold about 14.7 psi because of the chip?
thanks!
Old Nov 5, 2006 | 09:20 AM
david9999's Avatar
No it doesn hold 14.7 because of the chip. The K03 can only push so much air and at high RMP it runs out of breath.
Old Nov 5, 2006 | 09:25 AM
BigJC's Avatar
Member
ORIGINAL: david9999
Yes, they are a small turbo having said that tho, if there is any restrictions in your intake then that will make the boost drop off quicker at high rpms
Old Nov 5, 2006 | 10:27 PM
AudiTurbo's Avatar
Like what kind of restriction?
Old Nov 6, 2006 | 03:30 PM
Jeff's Avatar
cloged filter
ORIGINAL: AudiTurbo
Old Nov 6, 2006 | 08:51 PM
AudiTurbo's Avatar
New filter and everything.....where is the best place for the boost gauge to hook up? thanks
Old Nov 6, 2006 | 08:59 PM
chuckievi's Avatar
Also open up your Forge DV and see what spring you are running. Too weak of a spring could have a detrimental effect. Despite what all those guys say, I have a 99 with a GIAC and I peak at 21 psi and it holds it for a good 1.5k RPM before slowly dropping off.
Old Nov 6, 2006 | 11:43 PM
AudiTurbo's Avatar
I have the yellow spring in now, and yeah thats the same with me.....it will go to about to 16 in 2nd and then fall off, and then in third i will go to about 20 or so, then it will fall off also.
how far does it fall of to....
