boost gauge
Old Nov 1, 2006 | 06:47 AM
MC Hammered's Avatar
Default RE: boost gauge
The Defi and Omori units were the most accurate, most responsive and required the least amount of air sampled to register a reading.
However these gauges cost much more than the other 3 brands.
You could buy a Stewart Warner gauge AND my pod for the cost of one Defi or Omori gauge.
Old Nov 1, 2006 | 06:54 AM
Cosmic Fur's Avatar
ORIGINAL: MC Hammered
What was the error range on the other ones?
Old Nov 1, 2006 | 07:22 AM
From the notes I took:
In the lab tests the Defi and Omori were accurate.
I had 2 Autometers, one with a carbon dial and another with a silver dial. The carbon dialled one had perfect vacuum reading and off by 1psi on boost, the silver dial one was off 2mmHg on vacuum and perfect on boost.
I had 2 Stewart Warner units and one was accurate on both vacuum and boost and the other I think the needle was misaligned as it was off by +3 throughout the scale. So instead of -21mmHg to 25psi it was -18mmHg to 28psi.
The VDO was off by 2mmHg on vacuum and 2psi on boost.
In the car when I hooked up 2 gauges the dial readings did reflect the findings above. The most noticable pairing was with the Omori and the misaligned Stewart Warner gauge when I was at idle where the needles were at different readings.
Old Nov 1, 2006 | 12:31 PM
aRIf's Avatar
I have Glow Shift Boost Gauge. It comes with 7 color. If I wanna be racer, just turn the color blur or green. It gives about 25hp
It reads 30psi that's why I got it. I had VDO and it was a great gauge.
Old Nov 1, 2006 | 04:33 PM
A4nicator's Avatar
I have had experience with Defi gauges and they are the best, but for a considerable amount. for only 2psi off Id get teh VDO and assume the error myself.
Old Nov 1, 2006 | 07:52 PM
The Bishop's Avatar
Get a cheap ebay one, they work fine. Spend your money on parts to make your car faster.
Old Nov 1, 2006 | 10:32 PM
Busted's Avatar
Defi gauges in audi a4
Old Nov 1, 2006 | 10:41 PM
  #18
Ford2Audi6's Avatar
Those look sick man but what about the center vents??
Old Nov 1, 2006 | 11:13 PM
  #19
twiggy114's Avatar
I think I will put this one small and compact.
Old Nov 2, 2006 | 12:20 AM
  #20
Ford2Audi6's Avatar
almost looks as if you have to squint to see it when your driving, but I have never seen one in person\.
