Boost gauge installed w/pics
Old Jan 4, 2006 | 08:43 PM
onepoint8tee's Avatar
Default Boost gauge installed w/pics
Well its done, pretty easy, just slightly time consuming, took about 2 hours...
Looks like im boosting around 17-18psi and spiking around 20-22psi. Vacum is about 20-22 at idle. I think thats all normal. SWWEEEET. No my dash isnt cracked, its a hairy peice of tape hanging on the bottom of the right vent.
[IMG]local://upfiles/10408/FA0342335D8B470292663563614817B4.jpg[/IMG]
[IMG]local://upfiles/10408/389B6F1D84844E3FA4260FD00E23B11D.jpg[/IMG]
[IMG]local://upfiles/10408/9DD54A1AD67E46628FBDBFEA70A173AF.jpg[/IMG]
[IMG]local://upfiles/10408/C8FBF0B60D1943D8885DF46E12E109C1.jpg[/IMG]
Old Jan 4, 2006 | 09:00 PM
TexasAudi's Avatar
Default RE: Boost gauge installed w/pics
looks good! how did you wire it in? or better yet did you use a diy from somewhere that i can follow?
Old Jan 4, 2006 | 09:04 PM
ORIGINAL: TexasAudi
I sort of used apr's instructions... I used the power wire from the wire for the vent lights, just spliced into it. Once you have the parts its pretty self explanitory. I did however somehow blow the low beam in my headlights.. I think it happend when i was testing for a ground.. How much are those bulbs anyone?
Old Jan 4, 2006 | 09:25 PM
_Adrian_'s Avatar
Check the fuses there should be a fuse for the low beams
Old Jan 4, 2006 | 09:26 PM
audiboy1618's Avatar
hhmm,i dont think you should be boost to 22psi, thats a problem, might wana look at that.
Old Jan 4, 2006 | 10:37 PM
north5995's Avatar
You are chipped right?
Stock, I am boosting around 6-7PSI. I am pretty sure thats normal. My Vaccuum is sitting where yours is through around 20-22.
Old Jan 4, 2006 | 10:39 PM
ORIGINAL: audiboy1618
No it spikes there... Boost is about 16 or 17 psi.. Ive seen it go to about 20psi just a few times while driving fast.
Old Jan 4, 2006 | 10:43 PM
sandman's Avatar
looks good, i like it. matches everything well too.
Old Jan 5, 2006 | 03:37 PM
drkenan's Avatar
Where did you get that pod? I installed mine last night with a crappy Apillar pod and this morning in the daylight it doesn't look that great...I need a center vent one.
Old Jan 5, 2006 | 03:48 PM
ORIGINAL: drkenan
Its an apr one. Got it from ecstuning.com.. Not cheap but better than what i could make.
