AudiForums.com
-   Audi A4 (https://www.audiforums.com/forum/audi-a4-8/)
-   -   boost gauges (https://www.audiforums.com/forum/audi-a4-8/boost-gauges-8582/)
Skibos 04-15-2005 02:44 AM
boost gauges
hey what is the difference on a boost gauge between vac and psi can i get one with just psi have no clue but want to pick one up tomorrow and put it in thx ............
brrman 04-15-2005 05:03 AM
RE: boost gauges
you want one with Vac also.
Vac will tell you how well your car is in vacuum when not accelerating/under boost (which is your psi).
It can tell you if you have a leak under vacuum.
ImolaS4 04-15-2005 05:30 AM
RE: boost gauges
A vac/boost guage is only a few dollars more than a boost gauge - well worth the extra $$.
Like brrman said, when you accelerate, you make boost (psi or bar). When you decelerate, you make vacuum (inches Hg).
You could have a leak in either direction.
brrman 04-15-2005 01:21 PM
RE: boost gauges
I currently have a vac leak and it is driving me nuts.
I was picking around at the vacuum system last night and found a small crack in a hose leading from my n75 valve.
This morning I can't get any more than 5 psi. LOL - checked the vag on the way to work and realized I didn't plug the
n75 valve back in (N75 open circuit code)
Skibos 04-15-2005 02:33 PM
RE: boost gauges
oooo ok i get it now i had a feeling that was how it worked im on my way out to get an auto meter as soon as i take a shower ...... hopefully it is a decent one ..... welll thanks guys
David_K 04-15-2005 03:46 PM
RE: boost gauges
just get the boost gauge it looks cooler than the vac/boost guage
brrman 04-15-2005 03:47 PM
RE: boost gauges
heh heh...easy to say when you don't have a vacuum system.
