boost gauges
Old Apr 15, 2005 | 02:44 AM
Skibos's Avatar
Default boost gauges
hey what is the difference on a boost gauge between vac and psi can i get one with just psi have no clue but want to pick one up tomorrow and put it in thx ............
Old Apr 15, 2005 | 05:03 AM
brrman's Avatar
Default RE: boost gauges
you want one with Vac also.
Vac will tell you how well your car is in vacuum when not accelerating/under boost (which is your psi).
It can tell you if you have a leak under vacuum.
Old Apr 15, 2005 | 05:30 AM
ImolaS4's Avatar
A vac/boost guage is only a few dollars more than a boost gauge - well worth the extra $$.
Like brrman said, when you accelerate, you make boost (psi or bar). When you decelerate, you make vacuum (inches Hg).
You could have a leak in either direction.
Old Apr 15, 2005 | 01:21 PM
brrman's Avatar
I currently have a vac leak and it is driving me nuts.
I was picking around at the vacuum system last night and found a small crack in a hose leading from my n75 valve.
This morning I can't get any more than 5 psi. LOL - checked the vag on the way to work and realized I didn't plug the
n75 valve back in (N75 open circuit code)
Old Apr 15, 2005 | 02:33 PM
Skibos's Avatar
oooo ok i get it now i had a feeling that was how it worked im on my way out to get an auto meter as soon as i take a shower ...... hopefully it is a decent one ..... welll thanks guys
Old Apr 15, 2005 | 03:46 PM
David_K's Avatar
just get the boost gauge it looks cooler than the vac/boost guage
Old Apr 15, 2005 | 03:47 PM
brrman's Avatar
heh heh...easy to say when you don't have a vacuum system.
blackcat01
Nov 18, 2008 10:08 PM
jojoenglish85
Nov 25, 2007 03:55 PM
Wintermute
Nov 22, 2006 08:30 PM
Audi son
Mar 15, 2006 01:49 AM
brkbeats
Feb 8, 2005 11:35 PM
