boost issues
Old Sep 13, 2006 | 06:07 PM
chuckievi's Avatar
Default boost issues
So I did the due search and whatnot and didn't find what I was looking for.
Since I got my GIAC chip I have noticed my car runs a lot better as far as MPG and whatnot, BUT I am still throwing the running lean cel code. I've replaced my MAF so now its down to a boost issue. If I understand it correctly since I am running lean the engine is getting less air that its expecting, thus a BOOST leak, not a vac issue. SO, whats the best way to find said boost leak? I don't really hear it or anything when I mash the gas I just know it must exist due to the cel.... any thoughts?
Old Sep 13, 2006 | 07:01 PM
BadLuckAudi's Avatar
Default RE: boost issues
running lean is more ain than fuel..... might have a fuel problem
Old Sep 13, 2006 | 07:06 PM
tooxtreme8813's Avatar
here is a DIY boost leak tester
Tools Needed:
1. Tennis Ball
2. Flat Head Screw Driver
3. Knife (to cut the tennis ball)
4. Compressor or Air Pump
Step 1: Get a tennis ball.
Step 2: Cut two holes in the tennis ball, one on each end.
Step 3: Should look like this on each end of the tennis ball.
Step 4: Go to your car an find the turbo inlet hose.
Step 5: Remove MAF and inlet hose from airbox or air filter
Step 6: Hook compressor or air pump to the tennis ball by sliding it in the holes you cut before.
Step 7: Place the tennis ball in the inlet hose and clamp it in using the existing clamp.
Step 8: Turn on compressor and pump air into the inlet hose. CAUTION: DO NOT OVER PRESSURIZE!!! 10psi should be more than enough.
Step 9: Now listen for air coming out of any boost lines or vaccume hoses. Now you should find your leak. Mine was here.
Old Sep 13, 2006 | 07:11 PM
chuckievi's Avatar
ah good stuff, i have a tennis ball and an air compressor.... oh wait i have knives too!
Could be a fuel problem....how? Fuel filter? or what? I NEED to get this fixed....
My thought that its a boost issue is because the car runs better and smoother since I installed the Chip.... would indicates to me the engine was lacking proper airflow before.
Old Sep 13, 2006 | 10:13 PM
chuckievi's Avatar
Took the car for a drive on my lunch tonight and I heard a boost leak. So hopefully its as easy as that.
Old Sep 13, 2006 | 10:33 PM
quattrosedan's Avatar
You would actually have a vacuum leak bc if you had a boost leak, you would be running rich.
Old Sep 13, 2006 | 11:43 PM
chuckievi's Avatar
right... so more air is getting to the engine than the ECU thinks should? I just replaced my MAF so I guess i'll see what I can find as far as leaks go...
Old Sep 14, 2006 | 02:40 AM
yes you have a vac leak, i had the same thing and it was throwing the code for lean it was P1136 or something like that. check the L-hose located behind the intake manifold as it is prone to tearing
Old Sep 14, 2006 | 01:18 PM
chuckievi's Avatar
Yeah if i had a clue what an intake maifold was I would be set Good news is I have the bently on it, hopefully it will tell me!
Old Sep 14, 2006 | 02:00 PM
InsaneHatter's Avatar
dont work on cars.. get some knowledge first, im not trying to be an ***, but if you dont know the difference between rich, and lean, and you dont know what an intake manifold is , i suggest you dont work on your car till you research a little
for reference.
RICH: To much FUEL in the AF = BOOST LEAK
LEAN: To much AIR in the AF = VAC LEAK
